Heteroskedasticity and Autocorrelation test for Panel Data
Posted: Fri Mar 23, 2018 8:35 am
by sarchi
hi,
I am trying to test for Heteroskedasticity and/or autocorrelation in my panel regression in Eviews 9. There do not appear to be the necessary tests available. The serial correlation LM test and Heteroskedasticity test is only available for a Undated Data. Is there another way to test them for Panel Data?
Tanz
Re: Heteroskedasticity and Autocorrelation test for Panel Data
Posted: Fri Mar 23, 2018 8:48 am
Heteroskedasticity tests are build in under View->Residual Diagnostics->Heteroskedasticity test.
The Arrelano-Bond autocorrelation test is available if you have estimated via DPD.
Posted: Fri Mar 23, 2018 9:08 am
by sarchi
Unfortunatly There is no Heteroscedasticity test in View->Residual Diagnostics->Heteroskedasticity test in my Panel Data. it is only available in undated Data .
and Arrelano Bond serial Korrelation test is only available for GMM equations estimated by first differentes.
Is there any other way?
Posted: Fri Mar 23, 2018 9:32 am
Posted: Sat Mar 24, 2018 3:37 am
by sarchi
Thank you for your answer. but in my Data is not Hetroskedasticity test Avalble. I have Student Version. Maybe is there problem?
Posted: Sat Mar 24, 2018 6:52 am
Do you have EViews 10 Student Version?
Posted: Sat Mar 24, 2018 7:02 am
by sarchi
I have student version 9.
Posted: Sat Mar 24, 2018 7:54 am
You’ll need 10
Posted: Tue Mar 27, 2018 2:48 pm
by sarchi
I have Eeviews student 10 installed. Now I have another problem. how can I remove the hetroskedasticity in EViews 10?
Thanx
Posted: Tue Mar 27, 2018 2:54 pm
There are a number of covariance matrix options available to rectify problems such as heteroskedasticity. Which one you use is entirely up to you and your data.
