Gaussian copula - toy example
Posted: Fri Mar 16, 2018 4:09 am
by joff
This is just a simple example of Gaussian copula written for educational purposes but maybe someone will find it usefull.
'Example of Gaussian copula with arbitrary marginal distributions (simulation and estimation)' wfcreate u 5000 scalar n = @obssmpl scalar k = 3 'Simulate k series using standard normal distribution and put them in matrix B_mat: series _x = nrnd series _y = nrnd series _z = nrnd stom(_x,x) stom(_y,y) stom(_z,z) matrix(n,k) B_mat colplace(B_mat,x,1) colplace(B_mat,y,2) colplace(B_mat,z,3) 'Calibrate the covariance (correlation) matrix A_sym: matrix(k,k) corr_mat corr_mat.fill 1, 0.7,-0.4,0.7,1, 0.1, -0.4, 0.1,1 sym A_sym = @implode(corr_mat) 'Simulate from multivariate normal using B_mat and Cholesky factor of A_sym: matrix chol=@cholesky(A_sym) matrix MVN_mat = chol*@transpose(B_mat) matrix MVN_mat = @transpose(MVN_mat) 'Create uniform marginals for each variable (u_*) and map them to arbitrary marginals (m_*) '(here Beta for x, Gamma for y and Normal for z) vector(n) u_x vector(n) u_y vector(n) u_z vector(n) m_x vector(n) m_y vector(n) m_z for !k = 1 to n u_x(!k) = 1-@cnorm(MVN_mat(!k,1)) m_x(!k) = @qbeta(u_x(!k),2,2) u_y(!k) = 1-@cnorm(MVN_mat(!k,2)) m_y(!k) = @qgamma(u_y(!k),2,1) u_z(!k) = 1-@cnorm(MVN_mat(!k,3)) m_z(!k) = @qnorm(u_z(!k)) next 'Put results in U_mat and XYZ_mat: matrix(n,k) U_mat colplace(U_mat,u_x,1) colplace(U_mat,u_y,2) colplace(U_mat,u_z,3) matrix(n,k) XYZ_mat colplace(XYZ_mat,m_x,1) colplace(XYZ_mat,m_y,2) colplace(XYZ_mat,m_z,3) 'This shows that that correlation structure is preserved for arbitrary marginals: freeze(MVN_correlation) MVN_mat.cov(outfmt=sheet) taua freeze(U_correlation) U_mat.cov(outfmt=sheet) taua freeze(xyz_correlation) xyz_mat.cov(outfmt=sheet) taua 'Estimating Gaussian copula, i.e. Pearson correlation matrix (coefficients), using Kendall's tau calculated from the simulated data (marginals) scalar pi = 3.1416 scalar ktau12 = @val(xyz_correlation(4,2)) scalar rho12 = @sin((pi/2)*ktau12) scalar ktau13 = @val(xyz_correlation(5,2)) scalar rho13 = @sin((pi/2)*ktau13) scalar ktau23 = @val(xyz_correlation(5,3)) scalar rho23 = @sin((pi/2)*ktau23)
