Store ARDL regression order in a scalar?
dravenous
Postby dravenous » Thu Mar 01, 2018 2:34 pm
Essentially I was wondering if I could get the order of my ARDL estimated equations into scalars so I could bulk test that the main RHS variable met a certain criteria. I have a large number of equations and I want to be able to loop through and flag when the main RHS variable coefficient is negative. The problem is with ARDL the spot of that variable depends on how many lags are chosen ,versus using regular LS where it's always the first coefficient in the coefficient vector. If I could extract the order of the ARDL I could tell my check where to look as it seems to always follow the pattern of LHS variable lags, RHS, RHS variable lags. TLDR:: if Eviews estimated an ARDL(2,2) can I get at that number in any straightforward programmatic way?
Thanks!
Re: Store ARDL regression order in a scalar?
Postby EViews Gareth » Thu Mar 01, 2018 2:45 pm
Easier to look up the RHS variable in the equation's varlist:
=EQNAME.@coef(@wfind(EQNAME.@varlist, "RHSNAME")-1)
dravenous
Postby dravenous » Thu Mar 01, 2018 2:57 pm
This worked wonderfully, thank you. SOO much more straight forward.
