Allow copy command in programs to copy a selected set or group of series at once between wf pages
Posted: Wed Feb 07, 2018 2:29 am
by mamo
Dear EVIEWS team,
I (still) use Eviews 9.5 Dec 2016 build
I would like to suggest to improve the copy command in the programming and command line environment so that it allows for copying a selected set or group of series at once between wf pages (see example program below).
I am aware of workarounds to achieve the same results, such as pagecopy (which requires defining a further intermediate page), but an extended copy command would be more straightforward.
Kind regards
mamo
wfcreate(page=p1) a 1990 2010 pagecopy(page=p2) series x=nrnd series y=nrnd series z=nrnd group gr x y ' The copy comand copies only the group definitions but not the series contained ' The 's' option doesn't apply here; it applies only when copying groups between wfs or dbs copy(s) gr p1\ pageselect p1 ' And also the following does not work ' pageselect p2 ' %serienames="x y" ' copy {%serienames} p1\ ' Yes, the following works, but then we end up with having also everything else in page 1 which is not what we want: pageselect p2 copy * p1\ 'More flexibility in defining the set of series to be copied yould be useful
