Cannot import more data (eviews 9.5)
Posted: Fri Feb 02, 2018 9:46 am
I created a worklie and past data from a xls file: The problem is that it has pasted only the first 225 columns (series) but not the 30 later (as if the capacity number was limited although it not the case). When I tried to past the 30 missed columns, the window suggested to import only the 224th series... it acts as if I can't add supplementary series.
I attached the files.
Thank you very much,
Regards
Regards
