What's the eviews equivalent of Excel's countif?
Posted: Thu Feb 01, 2018 4:00 pm
by miorinnovo
I want to know how many positive numbers are in a series. in Excel its a simple countif > o type formula. What would be the eviews equivalent?
Thanks!
Re: What's the eviews equivalent of Excel's countif?
Posted: Thu Feb 01, 2018 4:16 pm
@sum(x>0)
Posted: Fri Feb 02, 2018 8:06 am
by miorinnovo
Thanks but I'm not getting that to work.
I get this message:
NA found in matrix in "SCALAR TEST= @SUM(x>0)".
The sereies has some Nas, but even when I fill them in I get this error message:
Scalar sent to function which operates on a matrix in "SCALAR TEST=@SUM(x>0)".
Any ideas?
Posted: Fri Feb 02, 2018 8:24 am
Not sure, but are you sure that X is a series as opposed to a vector or matrix?
Posted: Fri Feb 02, 2018 8:56 am
You have to, unfortunately, do it in two steps.
smpl if x1>0
scalar test = @obssmpl
Posted: Fri Feb 02, 2018 9:12 am
by miorinnovo
Thanks Gareth!
Posted: Fri Feb 02, 2018 9:22 am
by miorinnovo
Can I use this sample sample trick to replace outliers in a series with NAs? Say I want to remove the highest and lowest 5% of observations in a series can i put somehting in this blank space that would do that?
Posted: Fri Feb 02, 2018 9:23 am
You certainly can, but look at the @replace function which might be easier.
Posted: Fri Feb 02, 2018 9:41 am
by miorinnovo
Im not familiar with the replace function but I found the following code which worked well. Thanks
series y = @recode(@abs(x) < @quantile(@abs(x), .9), x, na)
Posted: Fri Feb 02, 2018 9:47 am
I meant @recode. So you're ahead of me.
Posted: Fri Feb 02, 2018 9:48 am
by miorinnovo
ah, ok. Thanks.
