Box Cox Autoarma Error
Posted: Wed Dec 27, 2017 1:58 pm
by BCNAV
I've been using:
freeze(mode=overwrite,{%series}_stats) {%series}.autoarma(tform=auto,diff=2,select=aic,periods=12,kpsssig=5,eqname={%series}_eq,maxar=4,maxma=3,maxsar=1,maxsma=1,seed=131071,forclen={!fcst_length},etable,agraph,atable,fgraph) forecast
without issue.
However, when choosing the transform as Box-Cox (tform=bc, bc=2) I get errors stating "Attempt to raise a negative number to a non integer power". What is going on here? I have written a program that will find "optimal" lambdas and would like to use it, but even with the standard options I get this error.
Any ideas? Thanks
Re: Box Cox Autoarma Error
Posted: Wed Dec 27, 2017 2:55 pm
Is your copy of EViews up to date?
Seems to work for me:
wfcreate m 1990 2020 series y=rnd %series = "y" !fcst_length=12 smpl 1990 2019 freeze(mode=overwrite,{%series}_stats) {%series}.autoarma(tform=bc, bc=2,diff=2,select=aic,periods=12,kpsssig=5,eqname={%series}_eq,maxar=4,maxma=3,maxsar=1,maxsma=1,seed=131071,forclen={!fcst_length},etable,agraph,atable,fgraph) forecast
Posted: Thu Dec 28, 2017 7:43 am
by BCNAV
We are using the Enterprise Edition of 10+ Nov 30 2017 Build. Check for update says we are good. Rebooted machine and still the error. Error does not occur when using the GUI. The error only occurs when the tform option changes from tform=auto to tform=bc, bc=2. I plan to pass the lambda to bc with the optimal one found.
Note that if I use bc=1, 0.5, 0, -0.5, -1 are ok.
if lambda is 2 or -2 or higher/lower, EViews fails. With the positive 2 I get the error "Attempt to raise a negative number to a non integer power"
if I se lambda of -2 I get error "^ function given an out of range argument"
Lambdas of 2 and -2 are common, so I am not sure why EViews is bombing at the command line and not the GUI.
The manual says bc=int Set the power of the Box-Cox transformation. Only applicable if the tform=bc option is used.
Again, the GUI handles everything fine.
Posted: Thu Dec 28, 2017 9:24 am
Did you try the code:
Posted: Thu Dec 28, 2017 11:51 am
by BCNAV
Well I am totally messed up here...your code worked. I don't see where I am going wrong.
Here is my code. I still get the errors
close @all %m=@left(@date,2) %d=@mid(@date,4,2) !year=2000+@right(@date,2 !annual1=2000 !annual2=2020 %history_end_date="2017.11" %forecast_start_date="2017.12" %forecast_end_date="2020.1" !fcst_length=@datediff(@dateval(%forecast_end_date, "yyyy.mm"),@dateval(%forecast_start_date, "yyyy.mm"),"mm")+1 wfcreate arima_{!year}.{%m}.{%d} u !annual1 !annual2 %wfsaveloc="R:\Eviews\Workfiles\ARIMA\Fees" pagecreate m !annual1 !annual2 pagerename untitled1 navdat_m smpl @all FETCH(d=R:\Eviews\Databases\Main\nav_data_all_ts.edb) ovr_ecu_m11_n ovr_ecu_m14_n ovr_ecu_m22_n ovr_ecu_m23_n %vars="ovr_ecu_m11_n ovr_ecu_m14_n ovr_ecu_m22_n ovr_ecu_m23_n" for %series {%vars} smpl @first %history_end_date freeze(mode=overwrite,{%series}_stats) {%series}.autoarma(tform=bc,bc=2,diff=2,select=aic,periods=12,kpsssig=5,eqname={%series}_eq,maxar=4,maxma=3,maxsar=1,maxsma=1,seed=131071,forclen={!fcst_length},etable,agraph,atable,fgraph) forecast {%series}_eq.fit(e) {%series}_fit next
Don't know why this does not work.
Posted: Thu Dec 28, 2017 12:47 pm
by BCNAV
In the EViews database I am using, there are a total of 5 variables that exhibit this behaviour. That is, they cause crashes of EViews form within the program code, but work perfectly within the GUI. I can calculate Box-Cox transforms on my own and they work fine. This is a weird problem, which may be with EViews. Any other insight is great.
Posted: Thu Dec 28, 2017 12:52 pm
Would it be possible for you to provide the data?
Posted: Thu Dec 28, 2017 1:13 pm
by BCNAV
Yes I can. Workfile is attached (hopefully)
Posted: Thu Dec 28, 2017 3:14 pm
Can confirm I receive the same error. We'll investigate.
Posted: Thu Dec 28, 2017 5:20 pm
by BCNAV
Thanks...let me know when you can.
Posted: Thu Dec 28, 2017 5:30 pm
So what's going on is that for the (2,2,0,0) model, the forecast of the transform of the variable goes negative. Then EViews tries to un-do the transformation (which involves taking the square root), and fails, giving the error message.
You could try creating a series that is equal to the Box-Cox transformation of the variable yourself, doing the autoarma on it, selecting the correct model and then undoing the transformation manually. Yes this is a bit of a pain.
Posted: Fri Dec 29, 2017 9:31 am
by BCNAV
Thanks. I am guessing that autoarma is differencing (this is auto) the Box-Coxed variable and forecasting a drop (negative value) and transforming that negative drop back ("un Box-Cox"). This is problematic with a lambda of 2 (square root of negative number). I guess EViews tries to transform back before making a level forecast? If so, then perhaps it could be altered to take the forecasted change (which is what a difference is), add it to the previous Box-Cox value, then transform the whole thing back.
So my options, if wanting to use a Box-Cox transform are to:
1. Make the transform manually
2. Run autoarma to get the level forecasts (from differences if applicable)
3. Manually un-Box-Cox the forecast back.
This seem ok?
Thanks for your checking.
Posted: Fri Dec 29, 2017 9:56 am
Right.
