Rolling forecasts for GARCH model
Posted: Tue Nov 28, 2017 9:54 am
by Rstat
Hello guys. I am newbie in Eviews. I am stuck with an analysis. I searched all the forum and found some related topics about my problem. However, I could not manage to solve my problem.
My problem:
I have 964 return observations of a stock. By a windows size=200, I want to make rolling one a head forecasts for conditional variance using GARCH(1,1) model. And I also want to estimate the model coefficients at every 25 step.
For example,
- using observations from 1 to 200, first estimate the model coefficients, then using the estimated model, I want to forecast 201'th conditional variance,
- using observations from 1 to 200, first estimate the model coefficients, then using the estimated model, I want to forecast 202'th conditional variance,
- using observations from 26 to 225, first estimate the model coefficients, then using the estimated model, I want to forecast 226'th conditional variance,
-and so on.
I wrote such a code combining pieces from other topics. However, since I couldn't still gain the insight of the Eviews programming, I could not manage to solve the problem. My not working half code is as below:
' set window size !window = 200 ' set step size !step = 25 ' get size of workfile !length = 964 'calculate number of rolls !nrolls = @round((!length-!window)/!step) ' declare equation for estimation equation eq1 'matrix to store coefficient estimates matrix(3,!nrolls) coefmat ' where 3 is the number of coefficients matrix(1,964) results 'variable keeping track of how many rolls we've done !j=0 ' move sample !step obs at a time for !i = 1 to !length-!window+1-!step step !step !j=!j+1 ' set sample to estimation period smpl !i !i+!window-1 ' estimate equation equation eq1.ARCH(1,1) returnx eq1.forecast var rowplace(results, garch_n@ARCH(1,1), !j) 'store coefficients colplace(coefmat,eq1.@coefs,!j) next
I loaded the workfile as a attachment.
I will be very glad for any help. Thanks a lot.
Re: Rolling forecasts for GARCH model
Posted: Tue Nov 28, 2017 10:05 am
You don't say what the issue is, but looking at the code, one thing jumps out.
When using the equation.forecast procedure, you have to provide a name for the forecast of the mean equation, the standard error, and then the conditional variance.
http://www.eviews.com/help/helpintro.ht ... 23ww176268
