EViews 10 Install Failure
Posted: Tue Nov 21, 2017 12:14 pm
by Treeves
I have downloaded the full 64bit EViews 10 from the links supplied by IHS. I copied it locally.
I right click the exe and run as Admin, it starts the install then it fails with
EViews 10 install error.JPG (20.14 KiB) Viewed 15579 times
I have tried installing EViews 9 64bit with the same result.
I have also tried to install on multiple machines with the same result.
The log file is has a result code of -3.
Any ideas.
Re: EViews 10 Install Failure
Posted: Tue Nov 21, 2017 12:27 pm
Are you sure you're using the full installer and not the patch installer?
Posted: Tue Nov 21, 2017 2:55 pm
by EViews Steve
This can also happen if the EViews 10 installer previously crashed and left the registry settings in a bad state.
Download this zip file: https://eviews.com/misc/clean/reg_clean ... nstall.zip
Unzip it somewhere and run the "EViews 10 64-bit Clear.reg" file (just double-click the file to run) on the machine having the trouble. That should clear out the bad registry settings after which you should be able to run the installer again.
