SSPACE Near_Singular
osindi
Postby osindi » Tue Oct 24, 2017 5:49 am
I'm trying to specify a statespace model and estimate it.
However, it keeps saying that the matrix is near singular.
I'm only using two variables (P in the signal equation which is based on nairu, which is in turn based on the @state equation).
Any guidance would be appreciated
Using Eviews 9.5
Thanks,
ss_eg.wf1
(12.09 KiB) Downloaded 548 times
EViews Matt
Re: SSPACE Near_Singular
Postby EViews Matt » Wed Oct 25, 2017 8:47 am
It looks like the initial conditions of the estimation happen to produce a singular matrix. Try initializing your coefficients to something other than 0.
osindi
Postby osindi » Wed Oct 25, 2017 3:34 pm
Hi Matt,
Thanks for the suggestion. Unfortunately even after setting the initial conditions for the state space to nairu0 = 4.5, and nairusd0 = 1 i still get a near singular matrix without much else being said.
It's possible i've not set up the specification correctly, as i'm not sure what else is wrong here.
Any advice would be appreciated,
ss_eg.wf1
(12.6 KiB) Downloaded 551 times
EViews Matt
Postby EViews Matt » Wed Oct 25, 2017 4:22 pm
Did you try setting the 'c' coefficients so something non-zero as well?
osindi
Postby osindi » Thu Oct 26, 2017 12:53 am
I only realised after i posted that you meant initialise the parameters, and not the state variable.
That's working now, thanks!
