Importing hourly data from a file with hour numbers
Posted: Wed Feb 10, 2010 1:31 pm
A few customers have asked how to use a file containing hourly data with one column containing the day and one column containing the hour number (generally from 1 to 24). For example:
EViews 7 doesn't recognize this date format automatically (although it will if the second column contains times like '3:00' instead of integers), but you can give EViews something it will know what to do with by using the following expression as the 'date identifier series' during import or when restructuring the workfile.
This simply tells EViews to add 'hour-1' hours to the day series, which will create a combined date-time value that EViews will be able to recognize.
If the hours are numbered from 0 to 23, you can use the same expression without subtracting one from 'hour'.
day hour x
4/3/2008 1 100
4/3/2008 2 200
4/3/2008 3 300
4/3/2008 4 400
4/3/2008 5 500
4/3/2008 6 600
4/3/2008 7 700
4/3/2008 8 800
4/3/2008 9 900
4/3/2008 10 1000
4/3/2008 11 1100
4/3/2008 12 1200
4/3/2008 13 1300Code: Select all
@dateadd(day, hour-1, "h")If the hours are numbered from 0 to 23, you can use the same expression without subtracting one from 'hour'.
