I've been trying to get this working, with no success. I've read this forum thread:
http://forums.eviews.com/viewtopic.php?t=74
and still no help, because the data I'm working with is a bit special.
So here's what the data I have look like:
1. I have several EVIews (.edb) databases.
2. Each one, contains several variables in an undated/unstructured form.
3. One of the variables in each database is a character, called "customer". This contains the customer name. There's also a variable called "date", which contains information about the date, which is daily, in the format: "09/20/2017". Each database has data from one date/day.
So I'd like to import all these data and merge them, using the "customer" and "date" variables.
I've tried doing in many ways, but nothing works. Please help.
Re-structuring data from different databases into a panel
Re: Re-structuring data from different databases into a panel
Ok, one thing that seems to work:
1. Create a new workfile (unstructured)
2. Fetch the data from the first database (still, unstructured).
3. Create a second workfile (unstructured)
4. Fetch the data from the second database (still unstructured)
5. Append the data from the second workfile into the first workfile
6. Repeat steps 4 and 5 until all databases are appended into the same workfile
7. Restructure the workfile as a panel using the time/cross-section identifiers.
It seems to work. But given the number of workfiles I have to open and close, it is time-consuming and not elegant at all.
Anything that beats the above solution?
Thanks!
Thanks!
Bring them all into one page, then structure by those two series
That would be more elegant than creating a new workfile for each one. But is there a way I can append directly from a database into a page? When I try to import data into a page, it tends to overwrite existing data, instead of appending them.
