How to interpret results for Impulse, Granger
Posted: Tue Aug 29, 2017 3:44 am
by smrehman
Hi!
Sorry, I understand if the following questions are basic, but I have been trying to do research, and don't have anywhere else to ask. I hope you can help me!
My question is about Impulse Response is:
(1) how do I interpret whether my impulse response is (in)significant?
(2) And how do I know if its at a 1% or % level?
(3) And how do I see whether it's a strong relationship or weak relationship?
(4) And how many periods is it generally accepted for a short-run andmedium-run period?
In case of Granger:
(4) how do I interpret whether my Granger Causality result is (in)significant?
I have attached some examples on Impulse response functions and Granger causality results:
a) response of real stock return(RSR) on oil price shock (ROP)for Germany
b) response of (RSR) on (ROP)for Japan
c) response of (RSR) on (ROP)for UK
d) response of RSR on industrial production
e) Granger causality p-value for each country
Thank you in advance!
Re: How to interpret results for Impulse, Granger
Posted: Tue Aug 29, 2017 6:39 pm
by cgoes
If zero is outside the red-dashed band, it is statistically significant for a give confidence level.
It needs to be clear in the paper. If I recall the standard in Eviews is to show two standard error confidence bands (meanings it's slightly below 0.05).
That depends on the economic interpretation of responses. You can scale responses to be of a specific size.
Since we`re usually working with stationary variables when running VARs, we assume that over the long run shocks go to zero and variables revert to their means or trends. But whether they revert at a fast or slow pace will depend on how many periods it takes for the process to be completed and whether you`re working with monthly/quarterly/yearly data.
Posted: Wed Aug 30, 2017 5:11 am
by smrehman
thank you for your response!
in regardings to (1), so if I understand it correctly, all the graphs a b c d are insignificant?
for (2) yes, it's 2 standard errors. So if all my results are significant, it means that they are all significant at a 5% level (for example, a and c, but not b and d?)
I thought that significance was read off the y-axis?
Posted: Wed Aug 30, 2017 10:54 pm
by cgoes
Yes, only (d) is significant at periods 1-4.
