Portmanteau for VAR(p)
Posted: Fri Aug 25, 2017 5:02 pm
by NicolasR
Just as an academic exercise the following code performs the estimation of the multivariate Ljung Box test for VAR already available in eviews.
Best regards,
'Nicolás Ronderos Pulido - Time series analysis 'Test: Portmanteau for VAR(p) 'Lutkepohl (2005) 'H0: no autocorrelation until lag h '------------------------------------------------------- !h=12 'Max h %var="var01" 'Estimated VAR(P) '------------------------------------------------------- {%var}.makeresids group resids for !i=1 to {%var}.@neqn if !i<10 then resids.add resid0!i else resids.add resid!i endif next stom(resids,U) U=@transpose(U) 'Var-cov-aut error matrix for !i=0 to !h matrix(@rows(U),@rows(U)) C!i=0 for !t=1 to @columns(U) if !i+!t<=@columns(U) then matrix(@rows(U),@rows(U)) C!i=C!i+@columnextract(U,!i+!t)*@transpose(@columnextract(U,!t)) statusline !t endif next C!i=C!i/{%var}.@regobs next 'Q and adjusted Q vector(!h) Q=0 vector(!h) Qa=0 for !j=1 to !h for !i=1 to !j Q(!j)=Q(!j)+@trace(@transpose(C!i)*@inverse(C0)*C!i*@inverse(C0)) Qa(!j)=Qa(!j)+@trace(@transpose(C!i)*@inverse(C0)*C!i*@inverse(C0))/({%var}.@regobs-!i) next next vector Qsa={%var}.@regobs*Q 'T vector Qa=({%var}.@regobs)^2*Qa 'T^2/T-i vector(!h) pvaloresQsa=0 vector(!h) pvaloresQa=0 for !i=1 to !h if !h>2 then pvaloresQsa(!i)=@chisq(Qsa(!i),(@rows(U)^2)*(!h-2)) pvaloresQa(!i)=@chisq(Qa(!i),(@rows(U)^2)*(!h-2)) endif next freeze(resultado) var01.qstats(!h)
