rolling reg with diffrent y and diffrent x variables
dicuans
Postby dicuans » Sun Jun 11, 2017 5:34 pm
Hi all
Brass tacks, i'm doing a multiple regression consisting different dependent variables and independent variables in each equations.
some thing like this:
y1 = c + a + a(-1) + x1 + x1(-1) + e
y2 = c + a + a(-1) + x2 + x2(-1) + e
y3 = c + a + a(-1) + x3 + x3(-1) + e
yn = c + a + a(-1) + xn+ xn(-1) + e
could you help me with the code, also I want to store the r-squared. I've tried using eq{!i}_{!j} but i never succeed.
previously, I managed to do this regrression:
y1 = c + a + a(-1) + b +b(-1) + e
y2 = c + a + a(-1) + b +b(-1) + e
y3 = c + a + a(-1) + b +b(-1) + e
yn = c + a + a(-1) + b +b(-1) + e
here is the code:
'create vector to store r-squares vector(22) r2s 'create empty equation to be used inside the loop equation eq ''counter of how many equations we have run !rowcounter=1 'run pairwise regressions between each series for !i=1 to agr.@count %iname = agr.@seriesname(!i) equation eq.ls {%iname} c r_ihsg r_ihsg(-1) r_agr r_agr(-1) r2s(!rowcounter) = eq.@r2 !rowcounter = !rowcounter+1 next
another one:
'create vector to store r-squares vector(63) r2s 'create empty equation to be used inside the loop equation eq ''counter of how many equations we have run !rowcounter=1 'run pairwise regressions between each series for !i=1 to bas.@count %iname = bas.@seriesname(!i) equation eq.ls {%iname} c r_ihsg r_ihsg(-1) r_bas r_bas(-1) r2s(!rowcounter) = eq.@r2 !rowcounter = !rowcounter+1 next
could you help me to make single program for this (the first equation up there), instead multiple code?
regards,
dicuans
Re: rolling reg with diffrent y and diffrent x variables
Postby EViews Gareth » Sun Jun 11, 2017 9:10 pm
It is a bit abstract, but for:
You could do something like:
'create vector to store r-squares vector(22) r2s 'create empty equation to be used inside the loop equation eq ''counter of how many equations we have run !rowcounter=1 'run pairwise regressions between each series for !i=1 to y_group.@count %yname = y_group.@seriesname(!i) %xname = x_group.@seriesname(!i) equation eq.ls {%yname} c r_ihsg r_ihsg(-1) {%xname} {%xname}(-1) r2s(!rowcounter) = eq.@r2 !rowcounter = !rowcounter+1 next
dicuans
Postby dicuans » Tue Jun 13, 2017 6:53 pm
Hi Gareth,
It works, thank you for the help!.
Regards from Indonesia,
dicuans
