calculate random effects
Posted: Fri Jun 02, 2017 4:36 am
by Gude
I am looking to guidance on how the random effects (cross-section, time/balanced, unbalanced) are calculated. I do not mean the model coefficients but the random effects avaiable via View -> Fixed/Random Effects.
I did not find anything in the user's guide nor in text books.
Re: calculate random effects
Posted: Fri Jun 02, 2017 5:51 pm
It's based on the literature from the BLUP (Best Linear Unbiased Predictor) of the component effects. See, for example,
Goldberger (1962) or Baltagi (2001, Econometric Analysis of Panel Data).
Posted: Sun Jun 04, 2017 10:52 am
by sansa
Is there any legal version of this books online?
Posted: Wed Jun 07, 2017 6:18 am
by Gude
Thank you, Glenn.
Is there any guidance in simpler terms available?
Posted: Fri Jun 09, 2017 7:43 am
by Gude
Btw: The "Representations" (View -> Representations) seem a little odd:
Under "Substituted Coefficients", it is suggested to add the random effects to get the fitted values. But one gets the fitted values without adding the random effects. (Note: this is different in the fixed effect setting where one would indeed need to add the fixed effects)
Here is an example for the Grunfeld data in a one-way cross-section RE model:
Substituted Coefficients:
INV = -57.8460462503 + 0.109783684775*VALUE + 0.308110054652*CAPITAL + [CX=R]
And here for the one-way cross-section FE model:
INV = -59.0109113225 + 0.110124585857*VALUE + 0.310064218491*CAPITAL + [CX=F]
Posted: Mon Jun 12, 2017 12:05 pm
The representations view is for forecasting. For fitted values, simply subtract the residuals from the observed.
