State Space Model Initial conditions
Posted: Fri May 26, 2017 8:06 am
by AltynayUssem
Hello!
I am very new to the State Space modelling, and probably will ask easy questions.
I have @signal exrate = c(1) + b1*(brent) + c(5)*baserate + [var=exp(c(2))]. and @state b1= b1(-1) + [var=exp(c(3))]
what is c(2)? I cannot understand
Also in setting initial values for example using param c(1) 0.0006 c(2) -8.5, c(3) -7 , should these 0.0006, -8.5 be the initial values of each time series for example for c(1) this is the first value of exrate? or should I take as initial values the means of the time series? and a special note on c(2) which inital value should I put for it as it is specified as [var=exp(c(2))]?
Sorry and
Thanks,
Altyn
Re: State Space Model Initial conditions
Posted: Fri May 26, 2017 8:40 am
Hello!
Sorry and
Thanks,
Altyn
The c vector gives initial guesses of parameter values--nothing to do with initial values of a series. c(2) is a guess as to the log of the variance of shocks to exrate. c(1) is a guess as to the intercept in the equation.
