Importing csv file - series coming trough as alphas
macgibbonn
Postby macgibbonn » Mon May 22, 2017 10:53 pm
I am using Eviews 9.5 (32-bit version on an Enterprise licence)
I am importing a csv file (attached) of time series numeric data which contains occasional missing values as ".."
The simple import code I am using is:
import M:\ExportDirect.csv colhead=1 @freq Q 1986q1
Four (4) of the 152 series are being imported as alphas rather than numeric. These series are:
  • HLFQ_SMB1JCA
    HLFQ_SMB2JBE
    HLFQ_SMB3JBF
    HLFQ_SMB3JCK
While these 4 series all have occasional instances of "..", there are other series which also have instances of ".." which are coming through as numeric.
Any suggestions as to how I can get the import to recognise the ".." as missing values?
I tried the following, but it did not work:
import M:\ExportDirect.csv na=".." colhead=1 @freq Q 1986q1
Thanks in advance for any assistance
ExportDirect.csv
(26.8 KiB) Downloaded 330 times
Re: Importing csv file - series coming trough as alphas
Postby EViews Gareth » Tue May 23, 2017 7:44 am
The problem is that you actually have two different values for NA - ".." and "" (i.e. blank). EViews only recognises one at a time, so interprets the second as a character.
You'll have to convert them to series afterwards using @val (or change the source csv to only have one type of NA).
