Page 1 of 2
contemporaneous correlation in state equations
Posted: Thu May 18, 2017 7:52 am
by tadejus
Hi all,
I can't find this topic being mentioned and I am stuck with it..
Basically I want to introduce a contemporaneous correlation in state equation and can't find a way to circumnavigate the rule stating that all the dependent variables in state equations need to be lagged..
so my code which aims to estimate an output gap out of inflation and gdp data reading:
sspace gap
genr infla = log(cpi) - log(cpi(-4))
genr infla_lead = infla(1)
genr l_gdp = log(gdp)
genr gr = l_gdp - l_gdp(-4)
scalar crec = 1+@mean(gr)
scalar un = @mean(u)
gap.append @signal l_gdp = pot + gap
gap.append @state growth = c(2)*crec + (1-c(2))*growth(-1) + [var=exp(c(3))]
gap.append @state pot = pot(-1) + growth+ [var=exp(c(1))]
gap.append @state gap = c(4)*gap(-1) + [var=exp(c(5))]
ap.append @signal infla = c(6)*infla_lead + (1-c(6))*infla(-1) + c(7)*gap + [var=exp(c(8))]
gets stuck at the line
since growth is not lagged (and by definition it should not be)
so my question is on how to go about this problem?
Re: contemporaneous correlation in state equations
Posted: Thu May 18, 2017 8:08 am
Maybe the following:
Instead of growth, introduce a variable growth_next_year. In the equation for potential include growth_next_year(-1). Change the variable names in the state equation for growth to growth_next_year.
Posted: Thu May 18, 2017 8:11 am
by tadejus
I did try to do this and it does not work, probably because growth is not observable, but instead is estimated as a combination of observable average growth and an unobservable deviation from the average?
my observables are: gdp, u, cpi and potential
Posted: Thu May 18, 2017 8:18 am
What went wrong when you tried it?
Posted: Thu May 18, 2017 8:22 am
by tadejus
it gives back an error
Invalid lags or leads for state variables in state equation
"@STATE POT = POT(-1) + GROWTH+ [VAR=EXP(C(1))]" in
"DO_ BLAGRAVE.ML(MAXIT=1000)".
since contemporaneous correlation (i.e. non laged variables in the state equations are prohibited by definition - not that I see why)
Posted: Thu May 18, 2017 8:28 am
@STATE POT = POT(-1) + GROWTH_NEXT_YEAR(-1)+ [VAR=EXP(C(1))]
Posted: Thu May 18, 2017 8:51 am
by tadejus
yes but then you will run into the same problem when you try to define growth_next_year by saying
@state growth_next_year=growth(1) where eviews will not allow for lead variables in state equations
or
@state growth_next_year= c(2)*crec + (1-c(2))*growth + [var=exp(c(3))] '
where again you will run into a problem of contemporaneous variable on the RHS (growth)
if growth was observable then you could just generate it by definition but it is not and therein lies the problem
Posted: Thu May 18, 2017 8:52 am
or
@state growth_next_year= c(2)*crec + (1-c(2))*growth_next_year(-1)+ [var=exp(c(3))]
Posted: Thu May 18, 2017 9:06 am
by tadejus
or
but now you are just back to the old code only replacing the variable growth with variable growth_next_year and still there is no contemporaneous correlation in state equation..
Posted: Thu May 18, 2017 9:11 am
Sorry. You're right of course.
Posted: Thu May 18, 2017 9:19 am
Which variables do you want to be contemporaneously correlated?
Posted: Fri May 19, 2017 1:29 am
by tadejus
growth and pot in line:
so this line is telling us that the potential output (pot) is linked to the previous period potential output and with current period (!contemporaneous correlation!) growth..
this is a replication of the IMF paper on using kalman filter to separate the output gap and potential output out of GDP series and using only data on gdp, inflation and unemployment..
this can definitely be done in other software packages and I can't see why eviews would not support it..
Posted: Fri May 19, 2017 5:52 am
Why doesn't using growth_next_year lagged accomplish the same thing? (I may well be jet lagged and missing something)
Posted: Fri May 19, 2017 7:15 am
by tadejus
because growth is not observable but also estimated (bear in mind it is a potential growth) and as such must be declared in state and not sygnal equation..
once you declare it in state equation you will run into a problem of having to declare the growth_next_year as being given as a lead variable (growth(+1) which eviews again will not allow..
if you define it as a simple AR process (growth_next_year=growth_next_year(-1)+error) like you did with growth then you are basically just changing the name of the variable but not it's substance..
or did you have some other way of declaring it in mind?
Posted: Fri May 19, 2017 10:19 am
I'll admit upfront that I'm not following this thread carefully, and I'm not familiar with the application at hand, so I may be missing nuance in the way you want to construct the model. With those caveats, I'll note that if all you want is contemporaneous correlation between states, you can use the @ecov to allow for the errors to be correlated.
In my cursory decoding of the model, you have
I think that this can be reparameterized as
gap.append @state growth = c(2)*crec + (1-c(2))*growth(-1) + e1
gap.append @state pot = pot(-1) + c(2)*crec + (1-c(2))*growth(-1) + e2
gap.append @ename e1
gap.append @ename e2
gap.append @evar e1 = exp(c(3))
gap.append @evar e2 = exp(c(1))
gap.append @ecov(e1, e2) = c(4)
where the POT equation is derived by substituting in the contemporaneous growth equation and collecting error terms. If you are assuming the original state errors are uncorrelated, var(e2) corresponds to the sum of the original error variances, and the covariance between e1 and e2 is the variance of the original error in the growth equation.
