Estimation
Posted: Fri May 12, 2017 7:45 am
by Anidip Chatterjee
Hello everyone,
I'm a new user of EViews. I was doing ordinal logistic regression with three ordinal independent variables. But when I was proceeding through estimate equation and generating result this error message "Unable to compute automatic estimates of starting values. Use user-supplied starting values." was popping up every time. Where was the error? Can anyone help me how to run a ordinal logistic regression through EViews?
Re: Estimation
Posted: Fri May 12, 2017 7:50 am
Sounds like EViews was unable to compute the starting values automatically. You should try user-supplied starting values instead.
Re: Estimation
Posted: Fri May 12, 2017 10:36 pm
I'm not getting it. What does "user-supplied starting values" imply? What shall I do now?.....@EViews Gareth
Re: Estimation
Posted: Fri May 12, 2017 11:19 pm
Re: Estimation
Posted: Mon May 15, 2017 6:48 am
Got it. Results are coming now.
Thanks.
Re: Estimation
Posted: Mon May 15, 2017 7:08 am
I've attached a file here. I'm facing a problem when I'm copying result from EViews to elsewhere in estimation result. There are two options in Copy Options; "As Displayed" and "Using Highest precision". When copied as "Using Highest Precision", probability of "Product Effectiveness" is coming 5.97749 and when copied as "As Displayed", probability of that independent variable is coming 0.0001. This is huge variation in the result. Why does this result differ?
Re: Estimation
Posted: Mon May 15, 2017 7:15 am
by startz
When you're copying highest precision and pasting into Word you're not showing the digits at the right. That's what the "..." means. You're probably missing something like "E-05."
Re: Estimation
Posted: Tue May 16, 2017 4:36 am
Then what should I do? Copy as "As displayed" and what will show, will be the actual values?
Re: Estimation
Posted: Tue May 16, 2017 5:42 am
by startz
You may need to adjust the table width in Word.
