1st Difference
joannetan92
1st Difference
Postby joannetan92 » Fri May 05, 2017 9:27 am
My data is in quarterly and I am trying to see the value at level and 1st difference.
Normally the 1st difference is in DY=Y-Y(-1)
That's mean my result in 1st difference will be, for example forth quarter minus third quarter (in the same year different quarter).
How can I estimate year on year basic?
I want estimate the first difference like, 2015 Q4 minus 2014 Q4 (different year but same quater).
Re: 1st Difference
Postby EViews Gareth » Fri May 05, 2017 9:30 am
d(y,0,4)
joannetan92
Re: 1st Difference
Postby joannetan92 » Fri May 05, 2017 9:35 am
Hi Gareth,
mean that I need to genr d(y,0,4) ?
Re: 1st Difference
Postby EViews Gareth » Fri May 05, 2017 9:39 am
Or just use it in place.
joannetan92
Re: 1st Difference
Postby joannetan92 » Fri May 05, 2017 9:43 am
Sorry, I don't quite understand.
Let's say, I want to use it in Unit Root test? What should I select?
Attached the file below for your references.
joannetan92
Re: 1st Difference
Postby joannetan92 » Fri May 05, 2017 9:45 am
Screen Shot 2017-05-06 at 12.42.06 AM.png (141.54 KiB) Viewed 15975 times
Re: 1st Difference
Postby EViews Gareth » Fri May 05, 2017 9:48 am
show d(y,0,4)
joannetan92
Re: 1st Difference
Postby joannetan92 » Fri May 05, 2017 9:52 am
Screen Shot 2017-05-06 at 12.51.26 AM.png (147.32 KiB) Viewed 15965 times
Re: 1st Difference
Postby EViews Gareth » Fri May 05, 2017 10:00 am
If you like.
joannetan92
Re: 1st Difference
Postby joannetan92 » Fri May 05, 2017 10:05 am
Then how can I check wether is stationary at first difference or not ? :cry: :cry: :cry:
