Page 1 of 2
loop with @daycount
Posted: Mon May 01, 2017 7:23 am
by ch2324
Hi for all,
I have three problem with my three parts of program
a) when i use the command manually series d01=@daycount("1"), ..., series d07=@daycount("7") it work but by loop it doesn't work i receive an error message. for the second part i would like to make x01=d01-d07, x02=d02-d07,....,x06=d06-d07.
'part 01 for !i=1 to 7 series d0{!i}=@daycount("!i") next 'part 02 series x07=@daycount for !j=1 to 6 series x{0!j}=d0{!i}-d07 next
b) when i use series d_01=@daycount("1 5"),.., d_01=@daycount("3 7") it work but by loop it doesn't work.
'part 03 for !m=1 to 3 for !n=5 to 7 series d0{!m}=@daycount("!m !n") next next
could you help me please, any help would be grateful.
Kind regards.
Re: loop with @daycount
Posted: Mon May 01, 2017 8:58 am
by EViews Mirza
The function @daycount("weekday range") takes on a string argument. Thus, your loops will never work because you're feeding a numeric value where a string should hold. Here's the code you're looking for:
for !i=1 to 5 series d0!m=@daycount(@str(!i)) next
Posted: Mon May 01, 2017 11:47 am
by ch2324
Thank you for your response. :D
1/i get error message when i run the program. " D08 is not defined in "SERIES X0!J=D08-D07"." but i have not generate d08.
' part 1 trade for !i=1 to 7 series d0!i=@daycount(@str(!i)) next group g1 d* equation eq_trade.ls y c g1 'part 2 model01 series x07=@daycount for !j=1 to 6 series x0!j=d0!i-d07 next group g2 x* equation eq_model01a.ls y c g2 'make two goups containning: first diff, first diff+seas diff group dg2 group dsg2 for !k=1 to g2.@count dg2.add d(g2(!k)) dsg2.add d(g2(!k),1,12) next ' part 3 for !m=1 to 3 for !n=5 to 7 series d0{!m}=@daycount(@str(!m) @str(!n)) next next 'part 4 model01 regular diff equation eq_model01d.ls d(y) dg2 'part 5 model02 with regular and seasonal diff equation eq_model02ds.ls d(y,1,12) dsg2 ' part 6 model03: ma(1) equation eq_model03dsma.ls d(y,1,12) dsg2 ma(1) ' part 7 model04: ma(1) and sma(12) equation eq_model03dsmas.ls d(y,1,12) dsg2 ma(1) sma(12) ' part 8 final model equation eq_model05dsmas.ls d(y,1,12) dsg2 ar( 1 to 2) ma(1) sma(12)
2/i get error message when i run the part 3 this " D01=@DAYCOUNT(@STR(1) @S is an illegal or reserved name in "SERIES D0{!M}=@DAYCOUNT(@STR(1) @STR(5))"."
'part 03 for !m=1 to 3 for !n=5 to 7 series d0{!m}=@daycount(@str(!m) @str(!n)) next next
Posted: Mon May 01, 2017 1:10 pm
by EViews Matt
In (1), inside the second for loop you've used !i instead of !j.
In (2), you need to concatenate strings together with the + operator. @str(!m) @str(!n) should be @str(!m) + " " + @str(!n), since you need a space between the two numbers.
Posted: Mon May 01, 2017 2:15 pm
by ch2324
it works 100%. :) :D
thanks you so much EViews Matt & EViews Mirza.
a last question: how can genarate series contained number of weeks in month or in quarterly?
Posted: Mon May 01, 2017 2:29 pm
How would you define the number of weeks in a month? How many weeks were there in April 2017, for example?
Posted: Tue May 02, 2017 8:50 am
by ch2324
I see what do you mean Mr startz. Got it!
Posted: Wed May 03, 2017 8:38 am
by ch2324
i would like to loop with three different ways by @daycount:
1)the loop below generate 49 series, i would like to generate just 7 series d_mon_01,...,d_sun_07.
wfcreate m 1976m01 1990m12 for %d Mon Tue Wed Thu Fri Sat Sun for !i=1 to 7 series d_{%d}_0!i=@daycount(@str(!i)) next next
2)manually it work d_mon=@daycount("mon"),..., but with loop i get error message.
wfcreate m 1976m01 1990m12 for %d Mon Tue Wed Thu Fri Sat Sun series d_{%d}=@daycount(@str(%d)) next
3)when i make this manually it work series d_mon_thu=@daycount("mon thu"), but with loop i get error message:
wfcreate m 1976m01 1990m12 for %m Mon Tue Wed for %n Thu Fri Sat for !i=1 to 3 series d_{%m}_{%n}_0!i=@daycount(@str(%m) + " " + @str(%n)) next next next
4) could i make two series (frequency monthly) contained the number of weeks and fortnight?
Posted: Wed May 03, 2017 8:53 am
by EViews Mirza
Again, you are confusing string variables and numeric values. @daycount takes on a string argument. However, this time, your loop is running through %d which are already in string format. You cannot use @str(%d) @str() converts numeric values to strings, but %d is already a string. Secondly, to get your naming right, you have 49 series because you are creating a nested loop each with 7 iterations. Thus, 7x7=49. That's clearly not what you want. What you want is to have an additional index that updates by 1 every time you switch to a new loop iteration in %d. Thus, you initialize this index at 0 and then you update it every time the loop repeats. So, the code you are looking for is this.
wfcreate m 1976m01 1990m12 !i=0 for %d Mon Tue Wed Thu Fri Sat Sun !i=!i+1 series d_{%d}_0!i=@daycount(%d) next
Posted: Wed May 03, 2017 11:07 am
by ch2324
Thank you EViews Mirza.
1/the code below it work but it generate 9 series just i need this: d_mon_thu_01, d_thu_fri_02, d_wed_sat_03
!i=0
for %m Mon Tue Wed
for %n Thu Fri Sat
!i=!i+1
series d_{%m}_{%n}_0!i=@daycount((%m)+" "+ (%n))
2/ and for my question about weeks and forthnight?
Posted: Thu May 04, 2017 8:46 am
by EViews Matt
You don't want to use nested loops because you don't want every combination of your inner and outer loop values. However, EViews' for loops can iteration through several values at the same time:
wfcreate m 1976m01 1990m12 !i=0 for %m %n Mon Thu Tue Fri Wed Sat !i=!i+1 series d_{%m}_{%n}_0!i=@daycount((%m)+" "+ (%n)) next
Posted: Thu May 04, 2017 10:47 am
by ch2324
Sorry i haven't seen your reply. thank you.
how can loop like this: d_Mon_Thu_01, d_Thu_Tue_02, d_Tue_Fri_03, d_Fri_Wed_04, d_Wed_Sat_05.
Posted: Thu May 04, 2017 10:58 am
by EViews Matt
The quick-and-dirty way would be to change the list of days in the for loop, e.g., Mon Thu Thu Tue Tue Fri ...
Something more principled might be:
wfcreate m 1976m01 1990m12 %days = "Mon Thu Tue Fri Wed Sat" for !i = 1 to 5 %m = @word(%days, !i) %n = @word(%days, !i + 1) series d_{%m}_{%n}_0!i = @daycount(%m + " " + %n) next
Posted: Thu May 04, 2017 2:15 pm
by ch2324
I understand, thank you so much.
for my question about weeks and fortnight, there is no solution.
how can transfer the every last obs of week in month and date corresponding in the month from page freq weekly to the page monthly freq.
series date_lastw, series obs_lastw
Posted: Sat May 06, 2017 7:10 am
by ch2324
How can import the date and the value corresponding from my page weekly to my page monthly?
e.g. the date of the last week for every month and his value.
same for the fortnight frequency.
any help would be gratefully appreciated.
