Please help! Difficulty interpreting ADF and KPSS test results
Posted: Fri Apr 28, 2017 3:23 pm
by willforbes1
Hi, i am new to eviews and i am conducting a few statistical tests for my dissertation, i am unsure whether i should reject or accept the null hypothesis of stationary according the critical values. Any advice regarding this would be appreciated. Thanks in advance for your help.
KPSS test results:
t-statistic= 2.4160
1% value= 0.7390
5% value= 0.4630
10% value= 0.3470
ADF results:
prob.= 0.9716
t-statistic= 0.1863
1% value= -3.4426
5% value= -2.8668
10% value= -2.5697
Re: Please help! Difficulty interpreting ADF and KPSS test results
Posted: Fri Apr 28, 2017 4:43 pm
by EViews Mirza
Given your prob. value of the ADF test, you will most certainly NOT reject the null of a unit root for any reasonable significance levels. On the other hand, the null of the KPSS test is stationarity, but your statistic 2.416 is in the rejection region, so you will reject the null of stationarity and accept that your series has a unit root.
Posted: Sat Apr 29, 2017 12:50 am
by willforbes1
Hi, thanks for the quick response, this has really helped me. I also conducted a variance ratio test please could you take a look at the results from this test also if you dont mind? Should i accept the presence of a random walk or is there a random walk in the data? Thanks again in advance.
value= 0.621041
df= 523
probability= 0.9531
individual tests: stats for each period:
z statistics for period 2=-0.2306 prob=0.8176 variance ratio=0.9815
z statistics for period 4=0.3253 prob=0.7450 variance ratio=1.0461
z statistics for period 8=0.6210 prob=0.5346 variance ratio=1.1346
z statistics for period16=0.4766 prob=0.6337 variance ratio=1.1424
Posted: Sat Jun 04, 2022 12:23 pm
by pitsi
Dear all,
Could you please help me to understand if the variable has a unit root or not? The fact that the ADF t-stat is smaller than the critical value at 5% indicates rejection of the null but what about the critical value at 1% level of significance? In this case it indicates that null cannot be rejected and first differences should be tested, right? So which one should I account? Although I ve searched the forum for answers I couldnt find something relevant, so apologies if a post has skipped.
Null Hypothesis: L_IT_EV has a unit root
Exogenous: Constant, Linear Trend
Lag Length: 1 (Automatic - based on SIC, maxlag=15)
t-Statistic Prob.
Augmented Dickey-Fuller test statistic -3.655053 0.0272
Test critical values: 1% level -3.992933
5% level -3.426809
10% level -3.136666
*MacKinnon (1996) one-sided p-values.
Thank you very very much for your time in advance!
