I searched the web for a similar error but I found nothing similar so I'm posting this here.
When trying to access the Fred database through EViews 9.5 File -> Database I get this error for the Fred Database:
Database Error: FRED library error: 'Retrieving the COM class
factory for component with CLSID {CBE08C8E-1A6C-4211
-9D44-CECA4B26AD53} failed due to the following error:
80040112.'.
Any help would be gladly appreciated.
Fred Database Error
Re: Fred Database Error
Try running the command in the EViews command window and then select Yes(All).
Next restart EViews and try again.
Note: you will need to have admin privileges.
regcomponentsNext restart EViews and try again.
Thank you, that solved it. Regards!
