How can I retrieve statistics from a View of an object?
Posted: Wed Sep 17, 2008 2:03 pm
by Thommo
For example I can perform a Wald test from my equation, but I cannot retrieve the p-values and store them in a scalar in a program. Is there a way to do this?
Posted: Wed Sep 17, 2008 2:14 pm
Many of our Views, such as tests from an equation, do not have an inbuilt way to retrieve the statistics. However you can always retrieve values by first freezing the view into a table, and then referencing the cell containing that value.
For example:
freeze(tab1) eq01.wald c(1)=0 scalar f_pvalue = @val(tab1(6,4))
Re: How can I retrieve statistics from a View of an object?
Posted: Sat May 22, 2010 11:46 am
by kipfilet
Hey there, I want to extract F-statistics from Chow tables recursively (meaning I have to freeze around 130 tables and extract the F statistics). However, naturally, I get an error after the first one. Is there any command to close the table?
Posted: Sat May 22, 2010 3:12 pm
Which error are you getting?
Posted: Sun May 23, 2010 6:44 am
by kipfilet
Sorry, I'm not getting any error. It's just the Chow series that are not filled (just with N/As). I am sure I am doing something wrong with the way I specify the dates for the Chow test.
workfile taylor m 1999m01 2008m12 smpl 1999m01 2008m12 equation eq03.ls eonia c infl_h indgap series(120) chow_rec series(120) chow_rec_p !i=1 while !i<120+1 freeze(tabchow) eq03.chow @first+!i chow_f(!i,1) = @val(tabchow(6,2)) chow_f_p(!i,1) = @val(tabchow(6,5)) d tabchow !i=!i+1 wend d itera d eq03
Note: I have also tried replacing the @first+!i with 1999m01+!i, but eviews always tells me that this is an illegal date. Any thought on how to solve this? I have tried going through the command reference, but I was not enlightened on this issue.
Posted: Sun May 23, 2010 10:31 am
by Dataminer
kipfilet
The attached code (using ev5) may help you make progress. It does the same chow breaktest over and over. You can see that you have to work a bit harder ( I,ve not done it here) to supply the changing breakpoint date and the date has to imply sufficient observations in the earlier and later periods.
Gerald
workfile taylor m 1999m01 2008m12 smpl 1999m01 2008m12 ' series eonia = @rnorm series infl_h = @rnorm series indgap = @rnorm ' equation eq03.ls eonia c infl_h indgap series chow_f series chow_f_p !i=25 while !i<60 freeze(tabchow) eq03.chow "2001m01" chow_f(!i) = @val(tabchow(3,2)) chow_f_p(!i) = @val(tabchow(3,5)) d tabchow !i=!i+1 wend stop
Posted: Wed May 26, 2010 7:01 pm
by fmgoto
Concerning the "freezing 130 tables", you may as well just freeze the table with the same name and then delete it after you are through with it. It helped a lot when I started getting workfiles with millions of frozen VAR output tables! Just a thought!
Posted: Wed May 26, 2010 7:27 pm
Or, just use the mode=overwrite option on the freeze command.
Re:
Posted: Sat Jan 29, 2022 9:02 am
by adarshad
For example:
equation eq{!i}.ls Y{!i} C X{!i}A(-!bestlag_A) X{!i}B(-!bestlag_B) Y{!i}(-1) X{!i}G(-!bestlag_G) X{!i}C(-!bestlag_C) X{!i}B(-!bestlag_B)*X{!i}Z
I want to retrieve wald test values for this equation and store them
Can someone help me
Posted: Sat Jan 29, 2022 9:05 am
by adarshad
i want to run wald test for c3=0 hypothesis for the output of the equations and then store them ...can someone refer to the code
Posted: Sat Jan 29, 2022 9:08 am
by adarshad
and store the pvalue and chi square value for all equations
Posted: Wed Feb 02, 2022 10:42 am
by adarshad
eq!i.wald c(6)=0
FOR i=28
I want to store pvalues in word file or atleast in a table or somewhere together
can someone help
Posted: Mon Oct 09, 2023 2:42 pm
by Oikono26
i would like to write an algorithm in order to be able to retrieve the smoothing parameter (a) in a table. So i would like to do it 10.000 times and that's means i will have 10.000 times the value of a. Could anyone help me??
I have already written the following code for only one series with my data:
freeze ser01.smooth(s) ser01sm
With this command i have the table with the results from simple exponential smoothing which is done only in ser01 and obviously the smoothing parameter (a). It is located in a 8Ε cell. I want to retrieve it and put it in a table.
