VAR Forecast Statistics
Posted: Thu Mar 30, 2017 8:17 am
by goffbl
I'm getting strange results using the VAR Forecast dialog. I'm using EViews 9.5 and estimating a simple VAR for teaching purposes using d(Fed Funds), d(3 month Treasury), d(10 year Treasury), d(Baa rate) for 1954.1 2015.12 with underlying rates in percent. Taking the in-sample, static forecasts for Fed Funds rate over 2006.1 to 2007.12 as an example, the RMSE, MAE, and MAPE generated by the Forecast dialog are 5.4, 5.4, 99.9 even though the actual forecast series is nearly identical to the actual series. When I compute these manually, they are 0.13, 0.10, 2.10, which make sense. I examined the results with a different data set and generated similar "glithcy" results. If the data are entered in levels in the VAR, the forecast stats make sense, but when entered as d(*) and having Eviews integrate back to levels, something is going haywire.
Re: VAR Forecast Statistics
Posted: Thu Mar 30, 2017 8:21 am
Could you post the workfile?
Posted: Thu Mar 30, 2017 12:31 pm
by goffbl
I've attached it
Posted: Thu Mar 30, 2017 12:36 pm
And instructions on what you're doing...
Posted: Fri Mar 31, 2017 7:05 am
by goffbl
I've been generating these results from the VAR dialog windows. The commands would be
smpl 55.1 2015.12
var rates.ls 1 3 d(reff) d(rtb3m) d(rtb10) d(raaa) d(rbaa)
smpl 06.1 07.12
var rates.fit(g, e)
Posted: Fri Mar 31, 2017 8:05 am
Ugh, looks like we're calculating it between the tranformed forecast and the untransformed actuals. Bad. We'll fix. Thanks for letting us know.
Posted: Fri Mar 31, 2017 9:02 am
by goffbl
Thanks for looking into it
