LP test for unit root with break
Posted: Tue Mar 28, 2017 11:29 pm
by ngantran
Hi all,
I just modified a code for Lumsdaine-Papell test, based on codes provided by the Eviews experts (tcfoon and trubador). However, I think my code has bugs since the result is different from that of the expert's code. Could someone show me where I did wrong, please?
And how to obtain the t-critical value in context of LP test?
Many thanks
call lpa(y,"C",12) subroutine lpa(series y,string %Model,scalar maxlag) !trim = 0.15 'Trimming parameter series DY = D(Y) !nobs = @obs(y)-maxlag-1 smpl @first+maxlag+1 @last equation temp.ls dy c @trend y(-1) !aic0 = log(temp.@ssr/!nobs)+2*(temp.@ncoef/!nobs) !bic0 = log(temp.@ssr/!nobs)+ log(!nobs)*(temp.@ncoef/!nobs) !min_aic = !aic0 for !lag=maxlag to 1 step -1 equation temp.ls dy y(-1) c @trend dy(-1 to -!lag) !aic = log(temp.@ssr/!nobs)+2*(temp.@ncoef/!nobs) !bic = log(temp.@ssr/!nobs)+log(!nobs)*(temp.@ncoef/!nobs) if !aic < !min_aic then !min_aic = !aic !best_lag = !lag else if !min_aic = !aic0 then !best_lag =0 endif endif next smpl @all !znobs = @obs(y) - !best_lag !lower = 1+!best_lag+@round(!znobs*!trim) !upper = @obs(y)-@round(!znobs*!trim) vector(!upper-!lower+1) results smpl @first + !best_lag @last !t_min=1000 vector(2) breaks for !i = !lower to !upper for !k=!i +2 to !upper-2 series DY=D(Y) if !best_lag=0 and %Model = "A" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!k-2) else if !best_lag=0 and %Model = "B" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2)*(@trend-!i+2) (@trend>!k-2)*(@trend-!k+2) else if !best_lag=0 and %Model = "C" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!i-2)*(@trend-!i+2) (@trend>!k-2) (@trend>!k-2)*(@trend-!k+2) else if !best_lag>0 and %Model = "A" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!k-2) DY(-1 to -!best_lag) else if !best_lag>0 and %Model = "B" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2)*(@trend-!i+2) @trend>!k-2)*(@trend-!k+2) DY(-1 to -!best_lag) else if !best_lag>0 and %Model = "C" then equation temp.ls DY Y(-1) C @trend (@trend>!i-2) (@trend>!i-2)*(@trend-!i+2) (@trend>!k-2) (@trend>!k-2)*(@trend-!k+2) DY(-1 to -!best_lag) endif endif endif endif endif endif if temp.@tstats(2)<!t_min then !t_min=temp.@tstats(2) breaks(1) = !i 'Identified first break point. breaks(2) = !k 'Identified second break point. series DU1 = @trend> !i-2 series DT1 = DU1*(@trend-!i+2) series DU2 = @trend>!k-2 series DT2 = DU2*(@trend-!k+2) if !best_lag=0 and %Model="A" then equation lpa.ls DY Y(-1) C @trend DU 'Selected equation else if !best_lag=0 and %Model="B" then equation lpa.ls DY Y(-1) C @trend DT 'Selected equation else if !best_lag=0 and %Model="C" then equation lpa.ls DY Y(-1) C @trend DU DT 'Selected equation else if !best_lag>0 and %Model = "A" then equation lpa.ls DY Y(-1) C @trend DU1 DU2 DY(-1 to -!best_lag) 'Selected equation else if !best_lag>0 and %Model = "B" then equation lpa.ls DY Y(-1) C @trend DT1 DT2 DY(-1 to -!best_lag) 'Selected equation else if !best_lag>0 and %Model = "C" then equation lpa.ls DY Y(-1) C @trend DU1 DT1 DU2 DT2 DY(-1 to -!best_lag) 'Selected equation endif endif endif endif endif endif endif next next delete temp endsub
