Block exogeneity in VAR
akrohit
Postby akrohit » Mon Mar 20, 2017 1:37 am
Hi I am interested in estimating a 2 variable VAR, variables being x1 and x2 for p no. of lags. I want to impose block exogeneity whereby I can ensure that variable x1 does not impact x2 (x2 determined only by its lags) wheres x1 does not have such restrictions and is dependent on x1 as well as x2. How to do this? Plz guide.
Re: Block exogeneity in VAR
Postby EViews Gareth » Mon Mar 20, 2017 8:18 am
You can't do it in a VAR - you'd have to use a System Object.
Probably the easiest thing to do is first make a VAR, then use Proc->Make System, then delete the coefficients you wish to restrict to zero.
