Desperately seeking help: Out of Sample, recursive, one step ahead, GARCH volatility forecasting
Posted: Sun Mar 19, 2017 9:23 pm
I wish to forecast volatility of stock index returns using GARCH models. This entails firstly, estimating using GARCH models in-sample, and then doing an out of sample forecast to obtain the residuals/GARCH variance series, which I will then use in a forecast evaluation with actual volatility (proxy is squared returns in this case). I wish to do recursive one step ahead forecasts whereby the coefficients are re-estimated and then stored, so that I can then make a GARCH variance series/extract the residuals and compare it with my squared returns.
I'm not sure what I'm doing wrong. Have used the code below. I tried running it via File>New>program. I had already generated the GARCH equation and saved it. Tried modifying the code by entering my own sample dates and GARCH equation, but nothing happened.
To be frank, not sure what to modify, and what to leave out. When I try running the code and setting 5 maximum errors, I get the following errors:
To be clear, my in-sample period is from 5/31/1996 to 6/01/2006, whilst my out of sample period runs from 6/02/2006 yo 6/01/2016. Desperately need help and I'd be so grateful for any assistance on this.
Have also attached the workfile
%END is not defined or is an illegal command in "%END = "@LAST" ".
is not defined or is an illegal command in " ".
Syntax error in control statement in "FOR !I = 1 TO 5219-20+1-1 STEP 1".Code: Select all
'run rolling regression
' set window size
!window = 20
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation garcheqn
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'series to store forecast estimates
series fcast
'*EDITED: catching start and end points
%start = "@FIRST" '@otod(@ifirst(ser))
%end = "@LAST" '@otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
!j=!j+1
' set sample for estimation period
%first = @otod(@dtoo(%start))
%last = @otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
' estimate equation - where the equation is GARCH = C(6) + C(7)*RESID(-1)^2 + C(8)*GARCH(-1)
garcheqn.ARCH RT_ASX200 C AR(1) AR(2) MA(1) MA(2)
' 1-period-ahead forecast
%1pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%1pere = @otod(@dtoo(%start)+!i+!window-1) 'end point
'*EDITED
if @dtoo(%end) < @dtoo(%1pere) then 'check whether the forecast end point is greater than the workfile end point
exitloop
endif
' set smpl for forecasting period
smpl {%1pers} {%1pere}
' forecast with command *forecast* (see also *fit*)
garcheqn.forecast(f=na) yf
' set sampl to obtain the 4th period observation
smpl {%1pere} {%1pere}
' store forecasts
fcast = yf
smpl @all
show fcast.line
d(noerr) yf
