Using the file banglaanswers916.wf1 EViews 9.5 (64-bit Enterprise Edition) unexpectedly closes after
smpl 35 36
eq915e.forecast(d, e, g) lnaf @se lnafse
Note: No problem without forecast evaluation: eq915e.forecast(d, g) lnaf @se lnafse
Note: I am forecasting LOG(A), forecasting A is fine, even with forecast evaluation.
More information:
Problem signature:
Problem Event Name: APPCRASH
Application Name: EViews9_x64.exe
Application Version: 9.5.0.0
Application Timestamp: 56eafa1c
Fault Module Name: EViews9_x64.exe
Fault Module Version: 9.5.0.0
Fault Module Timestamp: 56eafa1c
Exception Code: c0000005
Exception Offset: 00000000003ff04c
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1043
Additional Information 1: 73b6
Additional Information 2: 73b6...
Additional Information 3: a8ea
Additional Information 4: a8ea...
Bug in forecast evaluation ARDL-model
- banglaanswers916.wf1
- (17.4 KiB) Downloaded 372 times
Re: Bug in forecast evaluation ARDL-model
What's your build date (Help->About EViews)?
March 17, 2016
Update to the latest.
