Cannot import .TSP files
adjaniga
Postby adjaniga » Thu Mar 09, 2017 7:28 am
Dear all,
I've been trying to import .tsp file into EVIEWS 8 without success. Anytime I try to open the file in the application, the following error pops-up:
I appreciate any help. Thank you in advance.
Re: Cannot import .TSP files
Postby EViews Gareth » Thu Mar 09, 2017 8:33 am
Can you provide the file?
adjaniga
Postby adjaniga » Thu Mar 09, 2017 9:06 am
https://web.stanford.edu/~clint/berndt/exer/2e6.tsp
Postby EViews Gareth » Thu Mar 09, 2017 9:19 am
That's not a TSP data file. It is a program script. EViews can only read the data.
adjaniga
Postby adjaniga » Thu Mar 09, 2017 12:40 pm
Ok, I see. So I presume it's not possible to open this script on Eviews? Maybe I don't understand the concept of scripts, but is it possible to view/open it through a statistical program or is there any other way to use this script in order to help me with a certain exercise for which this script should be a result?
Thank you.
Postby startz » Thu Mar 09, 2017 12:43 pm
You can download and then open the file in any text editor.
adjaniga
Postby adjaniga » Thu Mar 09, 2017 1:52 pm
I had a look on that, but I was kind of hoping for some actual results of the test. Does any program read the scripts in that file? I can also support with database corresponding to this script file.
Postby EViews Gareth » Thu Mar 09, 2017 1:53 pm
TSP is a separate software package. To run TSP files you need TSP.
