error in BQ factorization program
Posted: Fri Feb 17, 2017 11:06 am
by velasquez
I just started learning programming in eviews and hence need some help. I am trying to work out a BQ factorization for a bivariate system using the attached program. However, on running the program I get the following error message
Equation estimates not valid in "DO_EQ1.makeresids eps1"
Can anyone tell me where I am going wrong. The workfile and program file are attached for your reference. I am using eviews 6.
Velasquez
Re: error in BQ factorization program
Posted: Fri Feb 17, 2017 11:13 am
equation eq1 tsls
should be:
equation eq1.tsls
Posted: Fri Feb 17, 2017 11:29 am
by velasquez
Thank you very much. It worked.
Regards
Velasquez
Posted: Fri Feb 17, 2017 12:10 pm
by velasquez
I have another question, this time relating to the impulse response. In the BQ factorization, the response of the first variable (dhh_tl) is constrained to be zero with respect to the temporary shock (shock 2). But in the impulses, we find that dhh_tl is responding to shock2 significantly. Is there something wrong in the program.
Velasquez
