Durbin-Wu-Hausman Test
Posted: Fri Jan 27, 2017 4:25 am
by Saakshi
I need to perform Durbin-Wu-Hausman Test for an OLS estimate. The null hypothesis is "OLS estimators are consistent". Can you please help me getting some code on this or any idea.
thanks
Re: Durbin-Wu-Hausman Test
Posted: Fri Jan 27, 2017 4:55 am
by KrilleJ
If you generally use the following formula for the DWH test:
TestStat=d' * inv(Est Asy Var [d]) * d
where d is the difference between the IV and LS estimators, you can use the following command to extract the components needed:
matrix MyOLSBeta=OLS_eq.@coef
matrix MyOLSCov=OLS_eq.@coefcov
matrix MyIVBeta=IV_eq.@coef
matrix MyIVCov=IV_eq.@coefcov
The distribution of the test statistic under the null then depends on an appropriate number of DoF.
/K
Posted: Mon Jan 30, 2017 7:05 am
by Saakshi
Thanks.
I need one more explanation. I used TSLS for an estimation and then followed regressor endogeneity test that is Durbin-Wu-Hausman. My regressor turns out to be endogenous as the null hypothesis is accepted. So far this means that the regressor is endogenous, so in this case can I go back and perform my OLS or I have to stick to my TSLS estimates only.
I am bit confused in this.
Please help.
Posted: Thu Feb 02, 2017 4:21 pm
by Krille
If I recall correctly (you have to check) and read the test in the right way, a small observed value of the test statistic is an indication of OLS being "OK". The procedure should be described in detail in standard econometric books.
