Dynamic model, first order serial correlation detected
Posted: Sat Jan 23, 2010 4:21 pm
by um4rio
how do I remove the serial correlation in eviews? Most the methods I have found I cannot use because I have a lagged dependant variable as an independent variable..
thanks
Re: Dynamic model, first order serial correlation detected
Posted: Sat Jan 23, 2010 6:10 pm
If you're doing a regression, add AR(1) to the variable list.
Posted: Sat Jan 23, 2010 7:52 pm
by um4rio
thank you for your reply. How would this remove the serial correlation? Correct me if I'm wrong, but is this the 'cochrane-orchutt iterative procedure'? I read about this in a book today, however it didn't make it clear whether it was possible to use this to correct serial correlation when there was a lagged dependant variable as an independant variable - I'm guessing I can use it then?
thanks
Posted: Sat Jan 23, 2010 9:29 pm
This is almost (not quite) identical to the Cochrane-Orcutt iterative procedure, and it is okay to use with a lagged dependent variable.
Posted: Sun Jan 24, 2010 8:13 am
by um4rio
thanks for your help :D what is this procedure called?
Also, do i need to pay attention to how many iterations it takes? (i.e, on a regression that i tried of the form [ log(y) log(x1) log(x2) log(y-1) C @trend ar(1)] it said 'convergence achieved after 6 iterations') is this important and worth elaborating on? Or, should i just accept the fact that the serial correlation is removed and concentrate on my new coefficients?
thanks again
Posted: Sun Jan 24, 2010 10:12 am
The number of iterations doesn't matter.
You might read the section in the Help system under "How EViews Estimates AR Models."
Posted: Sun Jan 24, 2010 10:27 am
by um4rio
thanks that was very helpful, when referring to this is it ok if I refer to it as "the iterative procedure"? - or would a different name be more appropriate?
Posted: Sun Jan 24, 2010 11:11 am
Probably safer to say "an iterative procedure"
Posted: Sat Mar 13, 2010 3:55 pm
by Bigbrotherjx
I have a related question:
I have specified a partial adjustment model, but there is some serial correlation (looks like AR(1) disturbances).
If I include an AR(1) in the estimation line...does this change my interpretation of my partial adjustment model (and the coefficients that I'm backing out)? How do I interpret the coefficient on the AR(1) coefficient that shows up in the estimation output?
Also, can AR(1) disturbances be used in a system e.g. a SUR system?
Cheers
