Hello
I'm estimating a cointegrated panel model. I did the unit root tests, cointegration tests and estimation of the DOLS and FMOLS models. My question is how to know the level of significance of the statistics found? At the levels of 1%, 5% and 10%, usually presented by asterisks, respectively, *, **, ***. I can not see in the Eviews results.
thanks
Panel cointegration
Re: Panel cointegration
Can't you use the t-stats ans p-values?
/Krille
/Krille
gislaine_mq
Yes, but I was in doubt about the level of significance.
Gislaine
Gislaine
Ok, I see.
If your p-value is lower than 0.10 then you have one-star significance, lower than 0.05 two-star, and lower than 0.01 three-star-significance.
Hope this can help.
/Krille
Hope this can help.
/Krille
