The (not so) Dynamic forecasting in State Space models
jason_ll
Postby jason_ll » Tue Dec 27, 2016 11:54 am
I've estimated a state-space model and would like to produce out-of-sample forecasts for all the signal and state variables dynamically.
My signal equations contain lagged dependent variables.
The problem is that EViews treats those lags as exogenous variables. This makes it impossible for me to produce forecasts that are more than 1 step ahead.
For instance, let's assume "var" is a signal and "stat" is a state variable:
var = c(1) + c(2)*var(-1) + c(3)*stat +e1 @state stat = c(4)*stat(-1) +e2
EViews treats var(-1) as an exogenous variable, instead of recalculating it dynamically for the out-of-sample forecast.
Is there any way I can rewrite this to fix this problem?
Question 2 (less important): when forecasting, is there any way I can ask EViews to not overwrite historical data where it exists? (in other words, treat all actuals as exogenous, and forecast dynamically when the actuals do not exist - similar to checking the "For all other endogenous - Exclude for periods where Actuals exist" box in the model object)
Thanks a lot!
jason_ll
Re: The (not so) Dynamic forecasting in State Space models
Postby jason_ll » Tue Jan 03, 2017 9:00 pm
No answer. Does this mean it can't be done?
xprimexinverse
Contact:
Postby xprimexinverse » Sun Mar 05, 2017 3:07 pm
Take a look at the program below. I think it's possible to do it if you use the makefilter command and set-up a loop. I demonstrate this below by forecasting an AR(1) model from both the equation and sspace objects. This is a simple example, but the general idea should hold. You can do variations of this where you can re-estimate the model parameters, but I don't do that here.
You can view the program below or download it here:
dyn_sspace.prg
(3.51 KiB) Downloaded 871 times
Cheers,
Graeme
' -------------------------------------------------------------------------------------------------------------------- ' DESCRIPTION: State-Space model dynamic forecasting with lagged signal ' ' DATE: 05 / 03 / 2017 ' ' AUTHOR: Graeme Walsh ' -------------------------------------------------------------------------------------------------------------------- ' ******************************************************************************************************************** ' Pre-liminary set-up ' ******************************************************************************************************************** wfcreate(wf=example) Q 1980Q1 2017Q4 ' ******************************************************************************************************************** ' Create Simulated Data ' ******************************************************************************************************************** rndseed 123456 series e1 = nrnd series Y = 0 model AR2 AR2.append Y = 3.20 + 0.22 * Y(-1) + 0.15 * Y(-2) + e1 AR2.solveopt(s=d,d=d) AR2.solve series Y = Y_0 ' ******************************************************************************************************************** ' Restructure page for out-of-sample forecasting ' ******************************************************************************************************************** pagestruct(end=2020Q4) ' ******************************************************************************************************************** ' AR(1) Model ' ******************************************************************************************************************** ' Estimate model smpl 1980Q1 2017Q4 equation ARMOD.ls Y = c(1) + c(2) * Y(-1) ' Out-of-sample forecast smpl 2018Q1 2020Q4 ARMOD.forecast YF1 ' ******************************************************************************************************************** ' State-space model ' ******************************************************************************************************************** ' Create the sspace object sspace dyn_mod ' Measurement equation dyn_mod.append @signal Y = c(1) + c(2) * Y(-1) + 0 * sv1 + eps dyn_mod.append @ename eps dyn_mod.append @evar var(eps) = exp(c(4)) ' Dummy state equation (sv1) dyn_mod.append @state sv1 = 0 * sv1 + eps_sv1 dyn_mod.append @ename eps_sv1 dyn_mod.append @evar var(eps_sv1) = 0 ' Estimate model by maximum likelihood smpl 1980q1 2017q4 dyn_mod.ml ' Make copy of model with set coefficients dyn_mod.makefilter new_dyn_mod ' Copy the orginal series series Y_COPY = Y ' Loop for dynamic forecasting for !i = 0 to 11 smpl @first 2018Q1+!i new_dyn_mod.ml smpl 2018Q1+!i 2020Q4 new_dyn_mod.forecast @signal *F2 series Y = YF2 next ' Restore original series and tidy up smpl @all series YF2 = Y series Y = Y_COPY delete Y_COPY ' ******************************************************************************************************************** ' Compare Forecasts ' ******************************************************************************************************************** show Y YF1 YF2 ' ------------------------------------------------------------------------------------------------------------------- ' END OF PROGRAM ' -------------------------------------------------------------------------------------------------------------------
Last edited by xprimexinverse on Wed Mar 08, 2017 5:10 am, edited 1 time in total.
jason_ll
Postby jason_ll » Mon Mar 06, 2017 10:02 pm
Thanks Gareme for sharing your code. While this certainly works, I feel like the EViews built-in function should be doing a better job, and giving us more options.
xprimexinverse
Contact:
Postby xprimexinverse » Tue Mar 07, 2017 7:16 pm
Hi Jason,
Let me try again! =)
I understand that there appears to be some limitations to the sspace object; however, the state-space form is a very flexible mathematical structure, in the sense that many models, including the AR(1) model, have more than one state-space representation. The flexibility of the theory carries over to flexibility with the software.
I think the knack is to be aware of the state-space form used by the software (covered in the official documentation - but I'm sure you're aware of it anyway!) and use that to cast your model into a state-space representation such that the software can do all of the things you want it to do.
For example, an AR(1) model can be written with a lagged endogenous (measurement) variable in the observation equation or, equivalently (see footnote), an AR(1) model can be written with an augmented state vector where the lag variable is included in the state vector and spelled out in a state equation. The details of this are given in Harvey's textbook.
If you write the AR(1) model in the augmented state vector form (i.e. include the lag variable in the state vector and not as a pre-determined variable in the measurement equation) then the dynamic forecasting will work in EViews without the need for the makefilter + loop approach that I outlined in my previous post.
See the program below for an updated demonstration of this.
You can download the program here:
dyn_sspace2.prg
(4.34 KiB) Downloaded 868 times
Cheers,
Graeme
Footnote: OK, there are some minor differences which have implications for the uncertainty of the forecasts, but this is of second-order importance. For details, refer to Harvey.
' -------------------------------------------------------------------------------------------------------------------- ' DESCRIPTION: State-Space model dynamic forecasting with (1) lagged signal (2) augmented state ' ' DATE: 08 / 03 / 2017 ' ' AUTHOR: Graeme Walsh ' -------------------------------------------------------------------------------------------------------------------- ' ******************************************************************************************************************** ' Pre-liminary set-up ' ******************************************************************************************************************** wfcreate(wf=example) Q 1980Q1 2017Q4 ' ******************************************************************************************************************** ' Create Simulated Data ' ******************************************************************************************************************** rndseed 123456 series e1 = nrnd series Y = 0 model AR2 AR2.append Y = 3.20 + 0.22 * Y(-1) + 0.15 * Y(-2) + e1 AR2.solveopt(s=d,d=d) AR2.solve series Y = Y_0 ' ******************************************************************************************************************** ' Restructure page for out-of-sample forecasting ' ******************************************************************************************************************** pagestruct(end=2020Q4) ' ******************************************************************************************************************** ' AR(1) Model ' ******************************************************************************************************************** ' Estimate model smpl 1980Q1 2017Q4 equation ARMOD.ls Y = c(1) + c(2) * Y(-1) ' Out-of-sample forecast smpl 2018Q1 2020Q4 ARMOD.forecast YF1 ' ******************************************************************************************************************** ' State-space model - AR(1) version 1 ' ******************************************************************************************************************** ' Create the sspace object sspace dyn_mod ' Measurement equation dyn_mod.append @signal Y = c(1) + c(2) * Y(-1) + 0 * sv1 + eps dyn_mod.append @ename eps dyn_mod.append @evar var(eps) = exp(c(4)) ' Dummy state equation (sv1) dyn_mod.append @state sv1 = 0 * sv1 + eps_sv1 dyn_mod.append @ename eps_sv1 dyn_mod.append @evar var(eps_sv1) = 0 ' Estimate model by maximum likelihood smpl 1980Q1 2017Q4 dyn_mod.ml ' Make copy of model with set coefficients dyn_mod.makefilter new_dyn_mod ' Copy the orginal series series Y_COPY = Y ' Loop for dynamic forecasting for !i = 0 to 11 smpl @first 2018Q1+!i new_dyn_mod.ml smpl 2018Q1+!i 2020Q4 new_dyn_mod.forecast @signal *F2 series Y = YF2 next ' Restore original series and tidy up smpl @all series YF2 = Y series Y = Y_COPY delete Y_COPY ' ******************************************************************************************************************** ' State-space model - AR(1) version 2 ' ******************************************************************************************************************** ' Create the sspace object sspace dyn_mod2 ' Measurement equation dyn_mod2.append @signal Y = Y_STAR + eps dyn_mod2.append @ename eps dyn_mod2.append @evar var(eps) = 0 ' State equation dyn_mod2.append @state Y_STAR = c(1) + c(2) * Y_STAR(-1) + eps_sv1 dyn_mod2.append @ename eps_sv1 dyn_mod2.append @evar var(eps_sv1) = exp(c(3)) ' Estimate model by maximum likelihood smpl 1980Q4 2017Q4 dyn_mod2.ml ' Out-of-sample forecast smpl 2018Q1 2020Q4 dyn_mod2.forecast @signal *F3 ' ******************************************************************************************************************** ' Compare Forecasts ' ******************************************************************************************************************** show Y YF1 YF2 YF3 ' ------------------------------------------------------------------------------------------------------------------- ' END OF PROGRAM ' -------------------------------------------------------------------------------------------------------------------
jason_ll
Postby jason_ll » Wed Mar 08, 2017 8:33 pm
Thanks again. However, this is a univariate case.
My problem in the first post was that I wanted to model a signal variable using its own lag as well as a contemporaneous state variable.
So back to my example:
@signal var = c(1) + c(2)*var(-1) + c(3)*stat +e1 @state stat = c(4)*stat(-1) +e2
Now, sure I can redefine var as a state variable as follows:
@signal var = state_var @state_var = c(1) +c(2)*state_var(-1) +c(3)*stat +e1 @state stat = c(4)*stat(-1) +e2
However, in that case I get an error because I can't use a contemporaneous state variable in the equation of another state variable.
Even though I could use "stat(-1)" in this particular case without a problem, this is indeed problematic in the case of a bigger model where "stat" shows up in other signal equations.
Perhaps this would work... although it's very far from elegant:
@signal var = state_var @state_var = c(1) +c(2)*state_var(-1) +c(3)*(c(4)*stat(-1) +e2) +e1 @state stat = c(4)*stat(-1) +e2
If you have a more elegant solution for that, I'd be grateful. Either way, I will take your advice and look at the textbook.
