Using optimize command to construct a TGARCH with non-zero threshold
wxhdiy01
Postby wxhdiy01 » Mon Dec 19, 2016 4:25 pm
Hello!
I'm estimating a model with threshold (1 threshold, thus 2 regimes) in both the mean and variance equation, and since the threshold value is not 0, it seems that the TGARCH feature in Eviews cannot be directly applied. Therefore I tried the User-defined optimization in Eviews, but since it's my first time using it, I'm not sure if it's programmed properly. Now I'm getting errors saying some of the log likelihood equations are NA, which I should be able to fix if there's no other big issues with the program structure. Any comment on the program will be very much appreciated! The should be useful to other users as well if it works. Thanks!
Basically, I'm applying ML to two equations:
(1) dep = (beta(1) - beta(2)*regs(1) - beta(3)*regs(2) - beta(4)*regs(3)-beta(5)*regs(4)-beta(6)*regs(5)-beta(7)*regs(6)-beta(8)*regs(7)-beta(9)*regs(8))*(thresh<thresh_value)-(beta(10)-beta(11)*regs(1)-beta(12)*regs(2)-beta(13)*regs(3)-beta(14)*regs(4)-beta(15)*regs(5)-beta(16)*regs(6)-beta(17)*regs(7)-beta(18)*regs(8))*(thresh>=thresh_value) +et
(2) ht = (beta(19)+beta(20)*e(t-1)^2+beta(21)*h(t-1))*(thresh<thresh_value)+(beta(22)+beta(23)*e(t-1)^2+beta(24)*h(t-1))*(thresh>=thresh_value)
subroutine dtarch(series logl, vector beta, series dep, group regs, series thresh, scalar thresh_value, scalar sigma0) series et = dep - (beta(1) - beta(2)*regs(1) - beta(3)*regs(2) - beta(4)*regs(3)-beta(5)*regs(4)-beta(6)*regs(5)-beta(7)*regs(6)-beta(8)*regs(7)-beta(9)*regs(8))*(thresh<thresh_value)-(beta(10)-beta(11)*regs(1)-beta(12)*regs(2)-beta(13)*regs(3)-beta(14)*regs(4)-beta(15)*regs(5)-beta(16)*regs(6)-beta(17)*regs(7)-beta(18)*regs(8))*(thresh>=thresh_value) 'residual from SETAR series ht(10)=sigma0^2 'define the initial residual variance value for !n=1 to 172 'forecast residual variance for GARCH series ht(10+!n)=(beta(19)+beta(20)*et(9+!n)^2+beta(21)*ht(9+!n))*(thresh<thresh_value)+(beta(22)+beta(23)*et(9+!n)^2+beta(24)*ht(9+!n))*(thresh>=thresh_value) 'variance equation with threshold next logl = @log((1/ht)*@dnorm(et/ht)) 'construct logliklihood equation endsub series LL vector(24) coef_dtarch coef_dtarch=1 'set the inital value of coefficients to 1 group xs d_total_in_gdp(-1) d_total_in_gdp(-2) d_total_in_gdp(-3) d_total_in_gdp(-4) d_total_in_gdp(-5) d_total_in_gdp(-6) d_total_in_gdp(-7) d_total_in_gdp(-8) 'Group the autoregressive right hand variables scalar sigma0=@var(setar_resid1) 'define the inital residual variance as the unconditonal variance of the SETAR residual series d_total_in_gdp_lag=d_total_in_gdp(-1) 'threshold variable optimize(ml=1, hess=bfgs) dtarch(LL, coef_dtarch, d_total_in_gdp, xs, d_total_in_gdp_lag, 0.1888, sigma0) 'optimization using ML %status = @optmessage statusline {%status}
EViews Matt
Re: Using optimize command to construct a TGARCH with non-zero threshold
Postby EViews Matt » Tue Dec 20, 2016 11:08 am
The problem lays in the code generating series ht within your subroutine. At present, that series will contain NAs, which obviously causes the optimization to fail. I believe the syntax "series ht(something)=" isn't doing what you think it is, but if you describe your intent for the two lines that use that syntax, I'm sure we can come up with something appropriate.
