Error on forecast: "(1) is not a valid index for."
Posted: Sat Dec 17, 2016 7:27 am
by kcaron
I'm trying to run a forecast and each time I click the forecast button, I get the above error.
The version is EViews 9.5 September 21, 2016 Build.
The equation I'm running the forecast from is "Barometer Total AR"....
I had this issue once before, but somehow the error went away. It is back again, and I can't get past it.
File attached (please note it has links to Bloomberg).
wca diffusion index v2.wf1
(1.31 MiB) Downloaded 406 times
Re: Error on forecast: "(1) is not a valid index for."
Posted: Sat Dec 17, 2016 2:25 pm
Looks like an issue with links. You can convert the underlying series (barometer_total) to a series (open it, click on Properties->Values and select Numeric Data), then re-estimate the equation and forecast.
We'll fix the link issue though.
by kcaron
Thank you Gareth!
Sent from my iPhone using Tapatalk
