Non-Cholesky factorisation
Posted: Fri Dec 09, 2016 11:52 am
by Albert0
Hi all,
I am trying to modify a code in which a svar is estimated. In particular, what I want to do is to change the factorisation matrix which in the original is a standard triangular Cholesky, introducing an over identifying restriction. I am not good at programming in eViews but I think the part of the code I have to change is the following:
matrix A1= @cholesky(qresidcov)
Is there a simple way of doing this?
Many thanks,
Alberto
Re: Non-Cholesky factorisation
Posted: Fri Dec 09, 2016 12:34 pm
by EViews Matt
Am I correct in assuming that you currently have a reduced-form VAR, e.g., y = <lagged y terms> + A1 * u, and you now want to change the specification for A1? Take a look at the SVAR documentation and you'll see that you can easily specify this form of VAR using two "pattern" matrices. The documentation refers to the pattern matrices as A and B, and in your case A would be the identity matrix and B would be a lower triangular matrix with the new restriction(s) you want. You can then use your VAR object's "svar" proc to estimate your new A1.
Posted: Sun Dec 11, 2016 8:43 am
by Albert0
Hi Matt, thank you for your reply.
Yes, your assumption is correct. Actually, I am interested in the long run case, so I have to find the "C" matrix in the documentation you posted.
After several attemps and after looking at other eviews programming guides, I managed to write this part of code that seems to work pretty well:
varest.cleartext(svar) varest.append(svar) @lr1(@u2)=0 varest.append(svar) @lr1(@u3)=0 varest.append(svar) @lr1(@u4)=0 varest.append(svar) @lr2(@u3)=0 varest.append(svar) @lr2(@u4)=0 varest.append(svar) @lr3(@u4)=0 varest.svar(rtype=text,conv=1e-5) matrix matb = varest.@svarbmat
The example is for the Cholesky case and I get the same matb matrix as in my original code. The only problem is that this procedure does not seem to store in any way the "C" matrix I need.
I would be grateful if you could give me your opinion on the code above and on how to save the "C" matrix.
Thanks a lot,
Alberto
Posted: Mon Dec 12, 2016 10:47 am
by EViews Matt
The most concise way to recover the C matrix is to utilize the the coefficients that are saved in the "c" object of the workfile page when you run the var's "svar" procedure. Basically, you recreate the long-run pattern matrix shown in the SVAR results table, but include the estimated values. For example,
matrix(4,4) matc matc.fill c(1), c(2), c(3), c(4), 0, c(5), c(6), c(7), 0, 0, c(8), c(9), 0, 0, 0, c(10)
Less concise, and less numerically attractive, would be to calculate Ψ and multiply it by the estimated B matrix. The only advantage of that approach is that you don't need to reenter the pattern structure. If you find yourself needing to do a lot of these types of SVARs, it would probably be worthwhile to specify the long-run restrictions via a pattern matrix, e.g.,
matrix(4,4) patc patc.fill na, na, na, na, 0, na, na, na, 0, 0, na, na, 0, 0, 0, na
and then write a subroutine that uses the pattern matrix and the "c" object to recover the C matrix.
Posted: Tue Dec 13, 2016 12:28 pm
by Albert0
Thank you again Matt, your method works perfectly.
Just a note: I think you miswrote the first command that should be:
matrix(4,4) matc
Posted: Tue Dec 13, 2016 12:52 pm
by EViews Matt
Quite right, I've edited my previous post to correct it. That's what I get for retyping rather than cut-n-paste. :D
