I am trying to replace an endogenous variable with the series that has the trajectory I want in a model. How do I do so with command? I have read up on the commands exclude and override, but am not sure if that can be done. So, rather than EViews solving for the variable endogenously, I want this to be replaced by a set of other values.
Thanks!
Override/exclude in a model
Re: Override/exclude in a model
exclude it first (turning it from an endogenous variable into an exogenous one), then override it (telling EViews to use the alternate scenario values rather than the true/historical values). You'll have to create the trajectory series first.
jacarandas
Hi!
I sidetracked from this issue and am faced with it again.
So, I managed to exclude the series from my model. It solves.
But, do you have to rerun the model to use override?
If the excluded series is called series1, what should the override be called? I assume the override will be the trajectory series I want.
Would appreciate more explanation on this as the object reference to do this is confusing me.
If the series you are overriding is called "Y" and the scenario under which you are overriding it has an alias of "_1", then the series containing the overriding values must be "Y_1". You must create that series in the workfile first (and fill it with the values you wish Y to use).
