CEIC database
Posted: Wed Nov 30, 2016 4:10 am
I have access to the CEIC database, specifically the China premium database, both in eviews and via the CEIC data manager.
In Eviews I have successfully used the fetch command with links and the series picker. Works well!
One feature which could be improved is the series label and the series name, once they are imported into eviews.
While the Description field is correctly filled, the series name seems completely unrelated to the series code which one can lookup in the original CEIC windows interface, which has in general more functionality than the one embedded in eviews.
E.g. the series
ceic::sr88152247
in the CEIC interface is identified uniquely with the following code:
366379667 (CKBAYL)
Similarly, but less important, is the import of other metadata in the details for each series, e.g. units and source.
Can this be addressed?
thanks and best regards
gio
E.g. the series
ceic::sr88152247
366379667 (CKBAYL)
gio
