Near Singular Matrix Error for Impulse response fonctions
Posted: Fri Nov 18, 2016 10:02 am
In order to analyse the interactions between the following data, I made an SVAR:
- tourist arrivals in France --> A_TOT_SA
- accomodation capacity in number of rooms in hotels (in first difference) --> D(OFF_SA)
- a consumer confidence index for OECD countries --> D(E_OECD)
There is one last dummy variable for the Paris terror attacks (EVENT_ATT_NOV_15).
With these variables, I make the SVAR (SVAR):
1. I estimate the VAR with 4 lags (results in TABLE01)
2. Using matrixes ZA and ZB, I make the VAR and SVAR (results in TABLE02)
When I ask Eviews for the IRF, I get an Error Message: "Near singular matrix".
I aso installed the sirf add-in for scaled IRFs, I also get the same message.
Why is that?
One last things that might help: on the IRF menu, when I switch the Analytic (asymptotic) to None in the Response Standard Errors section, I get the IRFs but without the confidence intervals. Could you please tell me why this is happening?
Thank you very much,
Best regards,
Why is that?
Best regards,
