Model selection with AIC etc.
Posted: Thu Jan 14, 2010 9:37 am
by huseyinky
Hi everybody. I have following problem;
I have estimated numbers of equaiton and try to find which one has lowest aic by following code
note: my equations are named as eq_0, eq_1.....eq_12
for !k=0 to 11 for !lag=0 to 11 !mininfocrit=999999 if eq_!k.@aic<!mininfocrit then !bestlag=!k !mininfocrit=eq_!k.@aic endif next next show eq_{!bestlag}
but this procedure does not show me the right equaiton. I can find minimum aic correctly, as I write down show !mininfocrit it gives the right value.
For any help, thanks in advance.
Re: Model selection with AIC etc.
Posted: Thu Jan 14, 2010 9:42 am
You probably don't want to be setting !mininfocrit=999999 inside your for loop.
Posted: Thu Jan 14, 2010 10:04 am
by huseyinky
Yes you are right. you are great.
!mininfocrit=999999 for !k=0 to 12 if eq_!k.@aic<!mininfocrit then !mininfocrit=eq_!k.@aic !bestlag=!k endif next show eq_{!bestlag}
ıt works very well. thank you very much.
