Pageload command does not structure workfile properly
Posted: Thu Nov 10, 2016 1:17 pm
by chester
I have data that is labelled by group. For groups with the word "Quarterly" in them, I'd like to import them into a workfile page that is structured in a Quarterly format. For some reason '@freq q' does not structure the workfile in a quarterly format but '@freq a' or '@freq m' structures the workfile properly. I attached a screenshot of the ID series and my code is below. Any help is appreciated! :D
%frequency="" if @instr(uniquegroups(result+1),"Annual")>0 then %frequency = "a" endif if @instr(uniquegroups(result+1),"Quarterly")>0 then %frequency = "q" endif if @instr(uniquegroups(result+1),"Monthly")>0 then %frequency = "m" endif pageload "P:\Knowledge\Data Resources\Databases\Scraper\newdata.csv" ftype=ascii rectype=crlf skip=0 fieldtype=delimited delim=comma byrow colhead=2 namepos=first eoltype=pad badfield=NA @freq {%frequency} @smpl @all
Re: Pageload command does not structure workfile properly
Posted: Thu Nov 10, 2016 2:08 pm
by EViews Steve
Can you post (or just a portion of) your CSV file?
Posted: Thu Nov 10, 2016 4:34 pm
@instr is case sensitive - I would guess you are never entering the if statement
Posted: Mon Nov 14, 2016 9:53 am
by chester
It appears EViews will not read quarterly time series data if it follows the format: "Q1 2012" - for example.
The workfile with imported data is unstructured.
However, if the data follows the format: "2012 Q1", the resulting workfile comes out structured as it should.
Is there any work-around here?
Posted: Mon Nov 14, 2016 11:18 am
by EViews Steve
Without changing the format of your date string, I can think of two options:
First, assuming your data is regular (meaning there are no gaps in the date column), you can simply import your data with a hard-coded frequency and start date - this will force the destination workfile to use your frequency and as long as the first data row matches the first hard-coded start date, the data should line up appropriately, like this:
import c:\files\q_year.csv @freq Q 1948Q4
This is the simplest option.
If your date values are not regular or you'd rather not specify a hard-coded start date, you can do the following instead:
First, import everything into a new undated workfile first (and make sure to read in your date column as an alpha series):
import c:\files\q_year.csv @freq U 1
Then create a new date series (i named mine DT2) that uses our @dateval function to convert your date column string (my date string column was named DT) into an actual date, like this (note the literal [Q] specified in the format string - this string is case sensitive so you must match it exactly to your date string):
series dt2 = @dateval(dt, "[Q]Q YYYY")
Then finally use the pagestruct command to restructure your workfile to use the new date series as your frequency:
pagestruct @date(dt2)
Once you have the workfile converted to the proper frequency, you can use the COPY command to put your new series objects into any pre-existing workfile that is already open.
copy Q_YEAR::* PREEXISTINGWF::*
To cleanup, you can simply close the workfile that was created during the import:
wfclose Q_YEAR
Posted: Tue Nov 15, 2016 1:59 pm
by chester
Thanks for the suggestion. I managed to find a work-around that formats my CSV data directly so EViews can read it.
