Windows Planner + Eviews
NikitaG
Postby NikitaG » Thu Oct 20, 2016 10:44 pm
Is it possible to set parameters somehow in windows planner such as openning a workfile and running a global process (command)?
Re: Windows Planner + Eviews
Postby EViews Gareth » Thu Oct 20, 2016 11:03 pm
Provide the name of an EViews prg as a parameter to the exe
NikitaG
Postby NikitaG » Thu Oct 20, 2016 11:25 pm
So I've tried several ways
The last one looks like this
"C:\Program Files (x86)\EViews 8\EViews8.exe"
Parameters: "E:\Eviews\1_pivots.wf1" "GO"
I've also tried
Parameters: "E:\Eviews\1_pivots.wf1" GO
"GO"
-"GO"
GO
I've tried lowercase go as well.
Am I doing something wrong here?
Postby EViews Gareth » Fri Oct 21, 2016 6:10 am
Where is the .prg?
NikitaG
Postby NikitaG » Fri Oct 21, 2016 7:01 am
E:\Eviews\SEP2016\go.prg
It also uses other global commands that are in this folder.
I just tried to change the default addins directory. Did not help.
I tried these
parameters "E:\Eviews\1_pivots.wf1" "GO"
or with these "E:\Eviews\1_pivots.wf1" "E:\Eviews\SEP2016\go.prg"
Postby EViews Gareth » Fri Oct 21, 2016 8:04 am
You can't use a wf1 as a parameter.
NikitaG
Postby NikitaG » Wed Oct 26, 2016 6:50 am
Thank you once again.
I figured it out, simply putting the wf destination in the program.
