Frequency problems
Posted: Wed Dec 23, 2009 6:28 am
Hi all,
I’m an EViews7-user.
I have a problem with organizing high-frequency data with a “frenzy” time scale and estimating spline-functions. The data is generated from a mud-core sample taken from the bottom of a lake in Norway. The time-scale is dated by C14-methodology. The problem is that the time frequency is 0.3969 years, i.e. the time difference between two observations is 0.3969 years (or 4.76 months!!). As you see – every 2.5 observation represents a year. Due to odd frequency it is not possible to organize the data so it could be possible to measure the seasonality-effects as we can do by using quarterly or monthly data. The scientific objective in this case is to measure the long-run properties (trend, cycles, structural changes/shifts etc.) in addition to estimating the statistical model.
I have the following question: Is it possible to reorganize the original data – and generate a new data-file, by (a) selecting, for example, every 10th observation (if we select every 25 observation then the time interval (frequency) is 10 years – alternatively (b) calculate the average of, say, every ten or 25 observation, and use these data as the new input file. (c) Let’s say that we want to estimate a spline-function but we do not know where the knots are located. The problem is: How do we estimate spline functions with unknown knots? How do we formulate the problem in EViews?
I appreciate a lot if you have some good ideas how to solve these problems. If you need to look at the original data-file, please let me know.
Regards,
Torbjørn
Regards,
Torbjørn
