Bloomberg database, import data
Posted: Tue Oct 18, 2016 3:47 am
by New
I just bought Eviews 9.5 and trying to connect it with the Bloomberg database (I also have Bloomberg prof.). I am using these steps:
http://www.eviews.com/EViews8/Enterpris ... tabase.pdf
I am able to open a window to bloomberg (FIle, open database, Bloomberg datebase). A window shows up (called database specification). I then click okay, and the Bloomberg database is open. I then browse for variables and these show up on the screen, but when I try to move it to the workfile it says:
"Bloomberg library error: "String was not recognized as a valid DateTime".
are you familiar with this problem?
I hope some of you can help me
Best regards,
Re: Bloomberg database, import data
Posted: Tue Oct 18, 2016 8:10 am
by EViews Jason
What is your EViews build date? Select help->EViews update to determine
Posted: Mon Sep 11, 2017 9:36 am
by cholke
Is there an update to this? I have successfully connected to Bloomberg daily for a year. As of Friday, I have received the same message about the DateTime string. Nothing has changed configuration-wise that I am aware of. Bloomberg still functions correctly as does EViews when using non-Bloomberg data.
I am using 9.5 Enterprise Edition - Dec 27 2016 build.
Thanks,
Craig
Posted: Mon Sep 11, 2017 9:55 am
by EViews Jason
We have noticed the Bloomberg servers have been flaky as of late. Most users have reported the problem going away the next day.
If you have admin privileges on your machine and are interested in helping to debug the issue, we can send you a test file that will generate output that we will submit in a detailed report to Bloomberg. Please send an email to support@eviews.com and refer to this thread.
Posted: Wed Sep 20, 2017 8:45 am
by EViews Jason
A patch for EViews 10 has been posted. Please let us know if the problem has or has not been resolved.
