copyrange is only available in EViews 7, but is fairly well documented in the Table section of the Object Reference.
I'll copy the relevant parts here:
table_name.copyrange s1 s2 destname d1
table_name.copyrange sr1 sc1 sr2 sc2 destname dr1 dc1
The copyrange command can be specified either using coordinates where columns are signified with a letter, and rows by a number (for example “A3” represents the first column, third row), or by row number and column number.
The first syntax represents coordinate form, where s1 specifies the upper-left coordinate portion of the section of the source table to be copied, s2 specifies the bottom-right coordinate, destname specifies the name of the table to copy to, and d1 specifies the upper-left coordinate of the destination table.
The second syntax represents the row/column number form, where sr1 specifies the source table upper row number, sc1 specifies the source table left most column number, sr2 specifies the source table bottom row number, sc2 specifies the source table right most column number. destname specifies the name of the table to copy to, and dr1 and dr2 specify the upper and left most row and column of the destination table, respectively.
places a copy of the data from cell range B2 to D4 in TABLE1 to TABLE2 at cell A1
table1.copyrange 1 1 1 5 table2 1 3
copies 5 rows of data in the first column of data in table1 to the top of the 3rd column of TABLE2.
