Creating links with foreign database
Posted: Mon Dec 14, 2009 7:17 am
by atoch
Bonjour,
I've been able to create a link for a time series from a foreign ( local Fame ) database using Eviews 6 and 7Beta graphical user interface by following these steps :
- define the database in Eviews registry (dbsource -> c:\temp\eviews.db)
- drag & drop series from the foreign database into my workfile
- opening the series (FRA_GDP)
- changing its properties, values to select database link.
- specify the specification for database fetch (dbsource::FRA_GDP)
I'd like to do the same in an Eviews program but I could you find the proper LINK::linkto syntax.
Thanks.
Arnaud Atoch
Re: Creating links with foreign database
Posted: Mon Dec 14, 2009 9:04 am
Once you've defined the database in the registry you can just do:
fetch(link) fra_gdp
Done!
Posted: Mon Jan 30, 2012 8:25 am
by atoch
Thanks,
I take from Eviews documentation that illegal names are automatically renamed :
From Eviews 7 command ref.pdf, p250
notifyillegal : When in a program, report illegal EViews object names. By
default, objects with illegal names are automatically
renamed. (Has no effect in the command window.)
Using the following Eviews commands get me a form prompting for eviews illegal name resolution while my understanding of the above documentation is that renamming should have been automatic.
dbopen(t=fame, s=frdb_r@asap1) adb_adbQ pagecreate(page=ADBQ) q 1950:1 2013:4 fetch(link, d=adb_adbq) usa.*
Posted: Mon Jan 30, 2012 12:32 pm
We haven't been able to replicate that using some test databases, it appears to work just fine for us. Could you provide some more details on exactly which database you're accessing?
Posted: Wed Feb 01, 2012 4:43 am
by atoch
Thanks ! it worked ... as soon as I was in a program rather than in the command windows.
Sorry.
Arnaud
