@wdrop statement
Posted: Fri Sep 23, 2016 1:07 pm
by Andre2016
Hello Guys,
So I have the following code :
smpl @all genr bbmodel = bbdmodel alpha bbmodel @wdrop ("Astra 1125SP" , "SP") @wdrop ("Astra 1125SPX" , "SPX")
Is there a way to write it so that I don't have to revrite the @wdrop statement on every single line?
Re: @wdrop statement
Posted: Fri Sep 23, 2016 1:47 pm
Currently those lines are not doing anything, so hard so see what you mean.
Posted: Mon Sep 26, 2016 11:23 am
by Andre2016
I have a series called "bbmodel" which is an alpha series that I'd like to edit.
In that alpha series I'd like the following action:
If what appears is "Astra 1125SP" then I'd like it to be only "Astra 1125"
If what appears is "Astra 1125SPX" then I'd like it to be only "Astra 1125"
Posted: Mon Sep 26, 2016 11:34 am
bbmodel = @replace(bbmodel, "SPX", "")
Posted: Mon Sep 26, 2016 11:37 am
by Andre2016
Thanks Gareth,
Posted: Tue Oct 04, 2016 1:27 pm
by Andre2016
I have an issue.
when I do
bbmodel = @replace(bbmodel, "Falcon 200", "Falcon 20")
All the values containing "Falcon 200***" changes e.g:
Falcon 2000S becomes Falcon 200S
Is there a solution so that when I change "Falcon 200" to "Falcon 20", everything else remain the same ?
Thnks
Posted: Tue Oct 04, 2016 2:01 pm
If there are spaces after the 200, you could include a space in the replace.
Otherwise you'll have to do a search replace with @instr, @left, @mid etc...
